Previous in Forum: Right Angle or Elbow Tube Insert   Next in Forum: Bearing Housing Tolerance
Why DG designed for 0.8 PF?
03/18/2011 10:01 AM
Hi,
I need technical clarification in usage of Diesel generator. Why all the generators are designed 0.8 PF?
Kindly clarify.
Bala
Re: Why DG designed for 0.8 PF?
03/18/2011 2:31 PM
yenbala; poor power factor overheats the generator .8 is factory tested for temperature rise on the windings. perry
03/19/2011 3:16 PM
There has been quite a few discussions on this subject
03/20/2011 5:10 AM
Dear yenbala,
In A.C Power system unity P.F for motor/drive may not be possible since the system needs the Inductance Effect.
At the same time Low Power Factor means higher Line Current, for the same load and resulting in more Heating takes place in the winding which is detrimental to the motor. Hence a balance is struck at 0.8 P.F.
If you desire you can have 0.95 P.F also.
DHAYANANDHAN.S
03/24/2011 9:41 AM
Mr. Bala, were you in the steel industry at one time?
Thanks
Ron
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Register to Reply 4 comments
Anonymous Poster (1); dhayanandhan (1); perry (1); ronclarke (1)
