Previous in Forum: Load Flow Analysis In ETAP Software   Next in Forum: Hyster Lost Drive
9 comments
Good Answers: 22
Three-Phase Motor Control
03/20/2011 1:04 PM
Hello all,
I am in the process of completing a design for a device to test HDPE drainage pipe. It involves a rolling carriage driven by 3 lead screws, through 3 roller chain drives, powered by a 3-phase AC motor attached to a gear reduction. There is only single-phase power available and the owner would like to be able to calculate or observe the forces required to engage and disengage the gasketed pipe joints. Since there will be various lengths of pipe in the tests and no set point for final joint engagement, it will be necessary to 'jog' and 'plug' the motor to permit an accurate final location for the carriage. Along with this aspect will likely be the need to have a constant torque motor to deliver the required torque regardless of motor speed.
I have learned that, along with the conversion of single-phase input current to operate a 3-phase motor, there is also the means to control the motor speed and observe or correlate the torque required for various carriage movements if the correct selection of motor type and control features is made. Unfortunately, I have been unable to obtain any substantive guidance from any of several so-called motion control experts. Some have said that it can be done, others say not so. I have been led to understand that if I utilize a vector motor with an encoder, I can, with the proper choice of controller, observe or correlate the torque exerted during various motion activities. However, I am still in the dark as to the appropriate component choices and their set-up. Incidentally, the use of permanent load cells is not an option on account of the forces applied to the platens during pressure testing. They could, however, be utilized initially as a means of establishing correlation between applied torque and resulting force.
I would be grateful for any learned input from the experts here.
Re: Three-Phase Motor Control
03/20/2011 1:11 PM
Sounds like a job for a common servo motor and controller unit. No big engineering mystery there.
03/20/2011 1:34 PM
I agree with tcmtech.
Still not sure why a load cell can't be used. Hell, a fish scale of the appropriate size would work for this.
Good Answers: 804
03/20/2011 5:29 PM
What amount of HP (lW) are we talking about here? If it's small, servo for sure but if it's big, Vector VFD with an encoder feedback would be better. There are several companies that make somewhat "universal" drives that can be used in either mode. Emerson / Control Techniques comes to mind first, they have a drive product called a "Unidrive" Siemens Sinamics S120 drives are also like that.
What you would do is set up the drive in a "torque follower" mode which will tell it to maintain torque as the most important output while running. All the while, the drive will be able to monitor the amount of torque it"thinks" the motor is putting out, check that against the performance of the motor, and determine an error, then correct for the error. You can observe any and all of those parameters on a smart system connected to the drive, i.e. a PC or SCADA HMI.
Any VFD can technically convert single phase input to 3 phase output, but you have to check with the individual manufacturer for the simple reason that they have to have designed it for that at the outset. The reason is that the VFD electronics needs to be powered up and on some VFDs the control power for that comes directly from the Line, as opposed to tapping off of the DC bus. If they tap off of the DC bus, the VFD doesn't care if the supply is 1 or 3 phase. If not, it may make a difference and so some mfrs include Phase Loss protection that cannot be disabled, rendering them unable to be used on a single phase source. So just check before buying.
But if you are not an EE with experience in this, it sounds like you need the services of a good Drives Integrator. Where are you in the world?
Good Answers: 22
03/20/2011 6:41 PM
Thanks, JRaef, yours is the first response that tells me I did not errantly post the question on some comedy forum.
It is a 3-hp motor and the anticipated maximum torque on the output side of the 30:1 gearbox is 1225 in-lb. I have looked at Emerson (US Motors) and Baldor.
I am in New Mexico and my business is specialty fabrication. Ususally, I would have the design provided, but not in this case.
Good Answers: 42
03/20/2011 11:46 PM
In my experience the correlation for torque is much easier to obtain from a DC machine.
The derived torque for an AC VFD (and most at 3 hp can be run from a single phase supply at this power level) is an estimated torque.
Depending on the accuracy you need you may still need to use load cells or direct toque measurement, especially if this is a certification procedure.
Good Answers: 804
03/22/2011 12:04 PM
No longer true with modern Vector drives.
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
03/22/2011 5:34 PM
GA with the first one BUT you are going to have that encoder hanging out to be hit and/or fail and the wiring from it to the VFD to shield, shield it GOOD
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
Good Answers: 42
03/23/2011 11:21 AM
It depends on the application. When there is a large "field" range as in a center unwind that was typically done with a DC motor (for argument 300HP) base speed 300rpm field weakend to 1500 rpm, the torque curve with field and armature current control is well defined. Even with 150% to 200% torque OL. Because an AC induction machine does not have a wide usable field range the frame size for this application becomes grossly oversize, and the torque regulation is now rather inaccurate due to poor resolution.
With a DC machine it is possible to run the application without "tension" feedback. With AC it has never been successful.
There are still nich applications where DC shines. I believe DC is best for wide field ranges and torque control.
AC shines in speed controled applications.
Perhaps I am still jaded by my experiences developing AC drives from the 60's. I am still pleasantly surprised when an AC drive performs as desired without a whole lot of tinkering. DC control is so simple in comparison.
03/21/2011 11:05 PM
Believe it or not, the electricity in your power lines IS three phase. Before it enters your house, it goes through a distributor transformer to convert it to single phase. However, power lines are EXTREMELY dangerous because they have 240V compared to our single phase houses with 120V. That is why it is occasionally used for industrial purposes, which require higher voltages. If you contact your hydro provider, they may be able to give you permission to access the three phase directly.
Although it is in the power lines, DO NOT try and hook your motor up yourself! Make sure you have contacted your hydro provider.
"I am the wisest man alive, for I know one thing, and that is that I know nothing."- Socrates
Register to Reply 9 comments
Doogleass (1); GW (2); JRaef (2); kwcharlie (1); lyn (1); sheepandgoat (1); tcmtech (1)
