Previous in Forum: AC Drive   Next in Forum: Please Help Me
REELING AND UN REELING CABLE
03/22/2011 8:56 AM
I need specification for reeling and unreeling duty flexible 4 Core X 16 Sq.mm cable. please help me
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
Re: REELING AND UN REELING CABLE
03/22/2011 10:04 AM
What has the manufacturer provided you with?
03/24/2011 3:22 AM
I don't know the exact words for specifying this, but in order to have a "neutral lay" (no tendency to twist or untwist under tension), the strands of each core may be twisted one direction, and the four cores in the opposite direction, so that these effects cancel each other. Another item to be specified is the allowable bending radius of the cable (no greater than the radius of the drum on which it is wound). (Alternatively, the drum radius can be specified as no less than the cable bending radius.)
Register to Reply 2 comments
