Previous in Forum: Windmill Blade Design   Next in Forum: Centrifugal Compressor Vs Blower ?
Pipe Size
03/26/2011 12:49 AM
what would be the pipe size for 10000 cfm?
Re: pipe size
03/26/2011 1:03 AM
Pipe is made by surrounding a hole with some solid stuff to hold in the stuff that goes through the hole, or pipe.
Knowing what stuff is going through the hole would help.
Re: pipe size
03/26/2011 3:36 AM
service- compressed air, of 10 kg/cm2,we require the pipe size for 10000 cfm flow.
Good Answers: 67
Re: pipe size
03/29/2011 3:02 AM
Pipe velocity for this application can be taken 8 to 10 m/s. Assuming pressure 10 kg/cm2 (absolute) and flow 10000 cfm at NTP, you require 12" pipe.
Good Answers: 130
Re: pipe size
03/29/2011 3:26 AM
He probably means 'expanded' - as in 'free air' - as in air tool rating.
[May be helpful if you stayed with one measurement system]
Re: pipe size
03/26/2011 1:35 AM
What fluid, how long is the pipe, and how much pressure drop is acceptable?
Good Answers: 11
Re: pipe size
03/26/2011 1:52 AM
Its something more like this. play & pick with the Reynolds number find the pipe size. All conditions are there given in the MooDy diagram.
Re: pipe size
03/26/2011 5:07 AM
On a quick search, I didn't find a chart that went to that high a flow. One hesitates to extrapolate, but from the trends in the following table, it looks as though 5" pipe would be about right. (But only with further confirmation.)
http://www.engineersedge.com/pipe_flow_capacity.htm
Register to Reply 7 comments
34point5 (1); khatri2435 (1); lyn (1); Noudge79 (1); pritam (1); Tornado (2)
