Previous in Forum: Boiler Feed Pump Abnormal Sccop/Speed variation   Next in Forum: Process Bag Filters For Cement Plant
Circulating Water Fibre System Problem
03/26/2011 2:50 PM
actually we have 8nos circulating pump,among them 2 nos for each 135 mw unit.whenever we stopped the circulating pumps of unit8 the valves for fibre filter damaged every time.fibre filter valve tapping taken from circulating water line valve specification:pn 10,300mm,cast body.please give possible reason for that.
Re: Circulating Water Fibre System Problem
03/27/2011 12:08 AM
You do not give enough information. Your English is very sketchy, so I don't understand the problem very well.
Let me try this:
  1. You have 8 pumps. True?
  2. Each 135 MW unit requires 2 pumps. True?
  3. The filter damage is only happening on the #8 pump. True?
How am I doing so far?
Good Answers: 181
03/27/2011 7:06 AM
10 out 10 for effort in the face of adversity.
Good Answers: 67
03/28/2011 3:24 AM
A picture speaks louder than thousand words. Why don't you post a line diagram indicating the positions of valves & pumps. Valves for fibre filter are damaging, not the fibre filter itself which may be weaker than valves.
Reason may be vapour lock. But to give conclusive answer, provide following information also:
1. Fluid temperature
2. suction & discharge pressure and NPSH
3. Type of valves, Nos installed for each pump/filter
4. Location of vents in the piping system
03/28/2011 9:07 AM
vent line is provided near water box of condenser and water temperature near about 32oC and water pressure maintained 1kg/cm2,valve made of cast and dia300mm and pn10.during stopping of pump valves of unit 8 fibre filter inlet got damaged.pump capacity 15600m3/hr
Good Answers: 67
03/29/2011 2:44 AM
Figure posted is not legible and clear. Can it be bigger & bolder. I understand that eight circles on top are 8 pumps (but not named 1 to 8), and four units are at bottom (but named different than 1 to 4). I still have following questions to correctly understand your problem:
1. What are four 135 MW units (what the produce)?
2. What are the suction and delivery pipe sizes? The valve size given 300 mm appears to be too small to handle 15600 m3/hr water.
3. Water pressure at both suction & discharge.
4. What are 5 vertical lines on right side? What are line sizes?
5. Which is pump 8? Where are the fibre filters located?
6. Type of valves (either of gate/globe/butterfly/plug/diaphragm...)
dev13459 (1); Mikerho (1); pritam (2); TonyS (1)
