Previous in Forum: Retrofit of R 22 Chillers   Next in Forum: Side-Cracks in Hot Rolled MS Plates
Any Room Heater is Suitable for Both Natural Gas and Propane Gas
03/26/2011 3:49 PM
I want to use natural gas for room heating because it is cheap. However, in case natural gas supply is temporarily shut down, I can use LPG instead. I can achieve this by either choosing a special design heater or choosing a 'fast convertible' conversion kit from propane to natural gas. Anyone has such an experience or knowledge? Is it reliable? Thanks
Re: Any Room Heater is Suitable for Both Natural Gas and Propane Gas
03/26/2011 8:19 PM
Some heaters are convertible between natural gas and propane. This typically involves changing an orifice and/or nozzle, easy to do with a small wrench. The pressures are different, and each type of fuel usually has its own pressure regulator.
