Greetings to you all,
I have a question i would like some advise on.
I have a Press brake, the hydraulic pump and electric motor are to be changed. The old pump has an inlet port on the base of the pump, and two ports on opposite sides of the pump housing, both going to a valve block.
I am assuming this powers two different functions from the same pump.
Could i replace the pump with a single ported pump but with a tee to split the flow to the different functions?
The press brake (Hydrabend 60t) is about 20 years old and no longer manufactured and finding information on it or parts are impossible.
I do have a rather fuzzy picture but not sure how to load it as yet.
