Previous in Forum: Car Brake   Next in Forum: Still Losing Coolant/Water No Leak Visable - 01 Dodge Ram 1500
Where is Coolant/Water Going?
03/30/2011 12:55 AM
01 Dodge Ram 1500 318/5.2- /recently replaced heads, and intake, where is coolant/water going?
Re: where is coolant/water going?s
03/30/2011 1:03 AM
Why did you replace heads, etc. in the first place? Water loss?
Give us something to work with besides a single non-descriptive sentence.
Good Answers: 97
03/30/2011 1:10 AM
Usually the same destination as the driver.
However sometimes there are leaks allowing the water / steam to escape.
If a gasket is blown - to the oil sump or released via the spring loaded filler cap / pressure release valve because of excessive pressure in the water system caused by "pumping" during the compression stroke .
A pipe may also perish or burst or leak at the joints.
The water pump could also be the culprit .
Get into the habit of checking the water (and fluid) level.
Good Answers: 58
Re: Where is Coolant/Water Going?
03/30/2011 9:17 AM
Go to the other thread you started on this subject, you are getting answers there.
Here is a link:
http://cr4.globalspec.com/thread/67443/Still-Losing-Coolant-Water-No-Leak-Visable-01-Dodge-Ram-1500
Register to Reply 3 comments
Hendrik (1); KJK/USA (1); lyn (1)
