Previous in Forum: RJ45 Connections for Cat5 Cable   Next in Forum: Progress Report of Research Project at MIT
Timer Relays and How They Work
04/07/2007 2:14 PM
hi there,
if was wondering if if any1 knew if you can get a relay with a longer timer say 1 hour to 10 hours and where abouts would you get this from?
as i am looking to add this to a 12v curcuit in which i could set the time to watever i wanted. say to come on in 10 hours and leave it and it will switch in 10 hours!
thank you any info would be great!
Re: Timer Relays and How They Work
04/07/2007 3:42 PM
Yes they are called plug in timers with fully progarammable twenty four hour setting some even allow for split timing of several items. Any hardware/electrical store Tandy/walmart?
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
04/08/2007 2:37 AM
There are numerous "repeat cycle" timers for daily periods or several times a day. Most operate on 120 VAC but you should be able find units that use 12 Volt (AC or DC) without using a converter. Try Newark, Allied or other electronic suppliers.
Location: Sunken Meadow (nee Rattle Snake Swamp) L.I., N.Y., U.S.A.
04/08/2007 4:44 PM
Rockwell Automation / Allen-Bradley, Fuji, and Omron make scads of different "Timers, Timing Relays, On - Delay, Multifunction, Solid-State Timers, 1/16 DIN Super Timers, et." These cost 50 to over 100 bucks, but MCM (www.mcmelectronics.com/) recently had some Omron timers (H3CR series) at about 1/3 list price. Most of these units mount in plug in bases like radio or TV tubes from the 1950's, but some have screw terminals. Go to any of their web sites for specifications. Some of these have delay times switcheable from seconds to minutes to hours to days. Their input and output voltage ratings range from 12V AC/DC to 240 VAC. Read the spec sheets.
Most people break things, engineers fix things.
Register to Reply 3 comments
BrainWave (1); MechanicOfNY (1); Tom Kreher (1)
