Previous in Forum: Orifice Plate Sizing Criteria   Next in Forum: What is EN8 Material?
11 comments
Weights of Mild Steel
03/31/2011 7:24 AM
hy
im chanchal
i want to know the equation for calculating all type of alloy steel and shapes
Re: weights of mild steel
03/31/2011 7:27 AM
Density of material x volume of material.
Densities can be found at sites such as
MatWeb - The Online Materials Information Resource
Good Answers: 18
03/31/2011 7:40 AM
What took you so long.
A whole 3 minutes.
More of a Cobra ready to strike than a Hawk/Vulture
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
03/31/2011 9:33 AM
I was asleep.
Good Answers: 18
04/01/2011 3:00 AM
Hi Lyn,
I suppose even Gurus have to sleep.
John
Re: Weights of Mild Steel
03/31/2011 11:59 AM
calculate what?
Title says weight of Mild Steel
Post says
i want to know the equation for calculating all type of alloy steel and shapes.
Equation for what?
Weight?
Weight = Density x volume x Acceleration due to gravity.
Find out the density from net/textbook etc. Though the best source will be ASM.
Calculate the volume - geometry
Find out the local g
Feed into the equation.
Anonymous Poster #2
04/01/2011 3:24 AM
Find out the local g?? does it make so much of a difference?
04/01/2011 4:07 AM
Unless you were doing analytical work, I'd think that the g value would be 1 for anywhere on earth. Sorry, anywhere on the surface of the earth.
04/01/2011 5:28 AM
9.8m/s2 ??
Good Answers: 137
04/01/2011 7:29 AM
The weight (force due to gravity) in lbf is numerically = to mass in lbm. So in effect the multiplier is 1 as Lyn says. If you multiply by g = 32 ft/s2 (as we're in lb and ft) the force is in poundal (not much used nowadays) and 32 poundal = 1 lbf.
In SI, where newton (N) is unit of force, N = 1 kg x 1 m/s2.
That's my take on it. anyway.
Cheers..........Codey
04/02/2011 8:30 AM
That is when you weigh (or compare with a known weight).
But when you are multiplying density with volume it will give mass. And Mass to weight conversion is dependant on g.
So Mass of a steel of 1kg is 1kg anywhere but its weight will be about 160 gram-force on moon
But that is actually splitting hairs (which warranted by the OP) by posting similar to one of the nth post on the same subject where n →∞ (or something very near )
Good Answers: 137
04/03/2011 11:52 AM
That's right, I don't disagree. I assume lbf is defined as 1 lbm at some standard value of g (32.2 ft/s2 ?). Can you confirm (or correct)? If so and he's somewhere where g differs from the standard he can correct, but for normal purposes anywhere on surface of Earth it's not likely to be necessary. So on Earth weight in lbf = mass in lbm near enough.
I was really replying to 4x4 in #8, and saying that I thought bringing g = 9.8 m/s2 into it explicitly could cause confusion.
Cheers.........Codey
Register to Reply 11 comments
4x4 (1); Anonymous Poster (3); Codemaster (2); jesw55 (2); lyn (3)
