Previous in Forum: Industrial Millwright Exam Prep CD?   Next in Forum: Magma Tidal Effects?
Blade Design for Wind Mill
03/31/2011 7:45 AM
Hi........
i am new to this industry of blade design
so i want study material for it like processing tooling, etc......
thanks in advanced.
Good Answers: 53
Re: Blade Design for Wind Mill
03/31/2011 12:53 PM
Your thank could be more useful if you would have posted it in more meaningful and constructive manner.
You look new in the forum too, better way is read all other post those are posted in similar fashion and how they are treated.You can not expect mango on a Acacia nilotica.
04/02/2011 4:01 AM
Thank You Mr. Rakesh Semwal for your advise,
next timeI will take care of it
03/31/2011 8:37 PM
These blades can be fiber reinforced resin that are baked in moulds. These moulds are heated and need temperature measurements at many points to know that the temperature us uniform. Thermocouples are typically used and may be measured with an analog to digital sensor like this M-7018R data acquistion module: http://www.icpdas-usa.com/products.php?PID=480 . Industrial controllers can read a module like this with Modbus RTU protocol and turn on and off heaters in zones to keep temperature uniform.
04/02/2011 4:04 AM
Thank You Mr. TechEric
I am gratefull to you.
priyankbarot (2); rakesh_semwal (1); TechEric (1)
