Previous in Forum: Power Saver in Lighting Load   Next in Forum: Harmonic Distortion
8 comments
REFR
04/01/2011 2:40 AM
plz. send the wiring diagrom of this relay
Re: REFR
04/01/2011 3:03 AM
Are you kidding? What relay?
India - Member - New Member
Good Answers: 164
Re: REFR
04/01/2011 3:14 AM
Heh heh..keep up with the times, the txtng lngg..... Restricted Earth Fault Relay.... rt OP?
Good Answers: 53
Re: REFR
04/01/2011 4:59 AM
No this is what he is looking for,
Re: REFR
04/01/2011 6:40 AM
April 1st is such an odd day....
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Re: REFR
04/01/2011 7:08 AM
hehehe :-)
One system
Re: REFR
04/01/2011 8:53 AM
Mr.Ravi we welcome you to this wonderful forum. Try to give maximum information while seeking help. Avoid abbreviations.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: REFR
04/02/2011 2:17 AM
A Restricted Earth Fault (REF) means an earth fault from a restricted/localized zone of a circuit. The term "REF protection method " means not to sense any earth faults outside this restricted zone. REF is a type of "unit protection" applied to transformers or generators and is more sensitive than the method known as differential protection.
An REF relay works by measuring the actual current flowing to earth from the frame of the unit. If that current exceeds a certain preset maximum value of milliAmps (mA) then the relay will trip to cut off the power supply to the unit.
Sure Answers Always
Good Answers: 164
Re: REFR
04/02/2011 4:51 AM
GA to you. Even though i can't read the diagram. We still don't know if what the OP refers to is a restricted earth fault relay. It can be a rare earth fertilisation relay for example. A good answer to a bad question
Register to Reply 8 comments
kvsridhar (2); loadshare (1); pravinba@yahoo.com (1); PWSlack (1); rakesh_semwal (1); Tornado (1); Vinu_Answers (1)
