Previous in Forum: CR4 posts using Google Chrome.   Next in Forum: Altitude Attitude Adjustment rev. 1
TO ADMIN ONLY
04/01/2011 4:17 AM
I continue to get 2 email inputs- one under ( I thought once you remove m S DIVEKAR- as user name it will go). Kindly remove this email id also from your list.
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
Re: TO ADMIN ONLY
04/01/2011 4:39 AM
Can you remove the ego and the superego along with the id?
--Siggy Freud
ξ
Re: TO ADMIN ONLY
04/01/2011 4:44 AM
λ
India - Member - New Member
Good Answers: 164
Re: TO ADMIN ONLY
04/01/2011 11:17 PM
For those of us slightly slow on the uptake,
a dictionary definition of "id"..
id
Pronunciation: (id), [key]
-n. Psychoanal.
the part of the psyche, residing in the unconscious, that is the source of instinctive impulses that seek satisfaction in accordance with the pleasure principle and are modified by the ego and the superego before they are given overt expression.
Good Answers: 59
Re: TO ADMIN ONLY
04/01/2011 7:26 AM
As you requested about a month ago, we changed the user name associated with the email address you posted because it had been your real name. Then, you created a second user name which you are now using. To avoid confusion I closed your first user name and so you should no longer receive any emails associated with that account.
If you wish to contact the admin privately in the future, you can email us at CR4 Admin @globalspec.com
Register to Reply 4 comments
Anonymous Poster (1); kvsridhar (1); lyn (1); SavvyExacta (1)
