Previous in Forum: Transite Pipe (Asbestos Concrete)   Next in Forum: Calculating MS Plate Weight
High Pressure Steam Welding Specifications
04/07/2007 9:43 PM
I am looking for specifications that I can download of the Web that outline standard welding specifications for welding pipe in a high pressure steam system exceeding 150 PSI. Thanks.
Re: High Pressure Steam Welding Specifications
04/08/2007 8:27 PM
It's all here ...
http://www.asme.org/Codes/
04/09/2007 2:41 AM
Refer to ASME Codes :
ASME B31.1 : Power Piping
ASME IX : Qualification Standard for Welding and Brazing Procedures, Welders, Brazers, and Welding and Brazing Operators.
ASME II, Part C : Specifications for Welding Rods, Electrodes, and Filler Metals.
04/09/2007 1:33 PM
Hola MWAllen. You may check The American Iron and Steel Institute (AISI), The American Weldding Society,The Procedure Handbook Of Arc Welding or check The James F. Lincoln Arc Welding Foundation. Regards. Luis.
Register to Reply 3 comments
Abdel Halim Galala (1); llizarraga (1); SolarEagle (1)
