Previous in Forum: Expansion Bolts?   Next in Forum: Pressure to Torque Using a Centrifugal Pump to Drive Additional Pumps for Work
14 comments
Checks on G A Drawing Of Compressor
04/03/2011 3:17 AM
I am very new in the consultancy sectory in rotary machines.Can anyone tell me the checks to be done in the GENERAL ARRANGEMENT DRAWING OF COMPRESSOR AND BLOWER.I DONT HAVE PEOPLE TO GUIDE ME and i have to do it all bymyself am reading books but still would require proper help from people who have experience if they can guide me a little
Good Answers: 16
Re: Checks on G A drawing of compressor
04/03/2011 4:41 AM
Ok now I'm curious... How to become a consultant and not have the experience necessary to make a GA?
I have known many men who went into the consultant field in the drilling industry for example, but only after many years of experience.
What industry are you working in?
04/03/2011 5:00 AM
Maybe his Daddy owns the company.
Good Answers: 53
04/03/2011 5:22 AM
Now a days ON CR4 you have to be presumptive and smart enough to score a good answer.No matter what the OP post, members need to make an assumption that fits to the best of their know how and post the answer.This is the new and creative way of getting too many good answers for a single lined ill-phrased question, Imagine every answer may be different but all are correct and GA.
This is 1111Th post, Magical number. I should have scored 33 GA to make it better.
04/04/2011 3:39 AM
sir i am not making a G A. I have to check the G A.I have experience in pumps but not in compressor so was just asking if I could get some help.
04/03/2011 5:31 AM
I think some of us may be confusing General Arrangement drawing with Good Answer.
Look junior, check the general arrangement drawing the see if everything is in the right place and it looks like the process will work.
Quit whining and start reading.
Good Answers: 53
04/03/2011 5:40 AM
Well caught, But thats only tail, General statement is still valid.I still have 10 Minuets but not going to change. to kep your statement valid.
Thanks anyway.
04/03/2011 7:21 AM
Thank you sir for your advice just sir i wasnt whinning but thought an experienced individual would definitely have more knowledge to me to guide me in wat direction i should go in checking and wat are the key areas to look in GENERAL ARRANGEMENT DRAWING OF COMPRESSOR AND BLOWERS.THanks by the way for ur time and advice
Good Answers: 181
04/03/2011 8:56 AM
If you want to be taken seriously as a consultant get out of the habit of using SMS TXT. It leads to confusion and I for one would bin any proposal that contained it.
04/03/2011 11:05 AM
sorry sir for using SMS TXT and making a miscommunication.
Good Answers: 61
04/03/2011 8:01 AM
I suggest that you go to this web site. Scroll down to the "Equipment" area, then choose the second item listed there.
http://www.pipingdesigners.com/Tools.htm
It does not have a listing for Compressor but by reading the full listings for Pumps and the other items you will get a wealth of ideas.
Good luck
Do it once and do it right
04/03/2011 11:07 AM
thank you sir. I atleast got some guideline with the link you gave.
Good Answers: 67
Re: Checks on G A Drawing Of Compressor
04/05/2011 7:26 AM
GENERAL ARRANGEMENT DRAWING OF COMPRESSOR AND BLOWER should have overall plan, elevation, side view(if required, both) and sectional views with broad dimensions. One isometric view is also needed to pictorially understand the piping connections. It should also contain the list with quantity & weight of various assemblies and sub-assemblies of compressor and peripheral equipments like lubricating oil unit, filtration system, inter-coolers, after cooler, silencers & noise hoods, capacity control system etc.
GA drawing should also have in brief major parameters like compressor type, flow rate, suction & discharge pressure, suction & discharge temperature, fluid to be handled, number of stages, rotor speeds, standards followed in design like API, details of drive like kW, speed, voltage & frequency for electric drive,
04/05/2011 7:30 AM
Thank you sir.I was seeing these all things only in GENERAL ARRANGEMENT DRAWING.Certain things that i was missing was told by you.thanks once again
Good Answers: 67
04/06/2011 12:20 AM
The most important thing above all the points enumerated at my post 12 for checking GA drawing is to check the space available at site for installation of compressor, compare with the dimensions and routing of piping for compressed gas and utilities like power and water.
Anonymous Poster (2); lyn (2); PennPiper (1); prashu_dhakate2005@yahoo. (3); pritam (2); rakesh_semwal (2); Tim in Mexico (1); TonyS (1)
