Previous in Forum: Hold On and Drop Down Characteristics of DOL Starter   Next in Forum: Machine Flexibility Upgrade 1
Application of Blackstart Generator?
04/04/2011 12:50 AM
what is the application of blackstart generator.
Re: application of blackstart generator
04/04/2011 2:31 AM
"Blackstart" refers to generators (or other equipment) that can be started without other sources of power already running in the facility.
Location: Far above all principalities and powers. Nigeria
04/04/2011 6:05 AM
Just like Tornado said, the blackstart like it's name sounds is for powering facilities from the scratch. Everywhere is black (when there is no power - darkness) and it has it's own fuel for power generation, maybe diesel. In my thinking I suppose through this black start generator, generators built specifically for the facilities powered by turbines for example can then be given initial excitation. Please get some more info from wikipedia Black Start
Re: Application of Black-start Generator?
04/05/2011 8:19 AM
The emergency generators at the Japanese nuclear plant were designed to be black start.
I am sure that the phrase is being redefined as we speak.
If you fail to follow through, you will fail.
Register to Reply 3 comments
otha (1); Toba (1); Tornado (1)
