Previous in Forum: "Hekatron" Fire Fiting System Control Panels   Next in Forum: Maintance Part in Cement Plant
Vibration Probe Setting
04/06/2011 1:49 PM
i am working on a project which is having VMS system and i don't know the how to set vibration sensors in the field if some body can explain me detail. i am using 3 wire system.
Venezuela - Member - New Member
Re: Vibration Probe Setting
04/06/2011 3:14 PM
Friend,
Can you tell us please which brand, models, if the measurements are radial, axial?
Regards
JP
Instruments-guy-SAV
04/06/2011 3:20 PM
it is for pump and motor.
04/10/2011 7:22 PM
Friend,
You are not saying nothing with pump and motor, you need to be more specific
Regards
JP
Instruments-guy-SAV
Good Answers: 116
04/11/2011 5:47 AM
Do you mean (1) how to set in place mechanically on the plant OR (2) Calibrate/check function electronically or with "shaker" table?? "VMS" suggests Vibrometer equipment, but as other posts write, type or part numbers are needed to understand what you have. Without those, no one can know what sensitivity or frequency range or signal type applies - or if position or motion is the essential detected value.
04/12/2011 7:37 AM
If all else fails, read the instructions.
67model (1); Instruments-guy-SAV (2); mdqamaralam (1); PWSlack (1)
