Previous in Forum: name of the different types of cable   Next in Forum: Sensor Issue
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Earthing, Grounding, Bonding
04/07/2011 9:31 PM
Once again, I have been challenged by the other layman asking me that what are differences among Earthing, grounding, and bonding?
Earthing (EU) and grounding (US), and they are used interchangeable. Is that correct?
They believe that the purpose of bonding is to electrostatic protection. But for me, bonding is a term that uses for general protection including electrostatic. The purpose is to ensure an equipotential system. Is that correct?
Anything that can go wrong, will go wrong
Good Answers: 140
Re: Earthing, Grounding, Bonding
04/07/2011 10:48 PM
Essentially, yes. It also provides a return path for fault current where the fault in the system is from an energized conductor to the bonding system. The impedance of the bonding system is to be as low as possible to facilitate an overcurrent device's functioning.
Involute Gear Hobs
04/07/2011 11:48 PM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Good Answers: 170
04/08/2011 9:57 AM
Very correct!
04/12/2011 7:20 AM
The difference between earthing and grounding is the Atlantic Ocean.
Good Answers: 170
04/12/2011 9:15 AM
Oh! That is the most cryptic reply! I will use it henceforth in my training sessions.
electricalexpert65 (2); North of 60 (1); PWSlack (1); robinwillson (1)
