Previous in Forum: Earthing, Grounding, Bonding   Next in Forum: Circuit Breaker - 0-co-coc
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Sensor Issue
04/08/2011 6:02 AM
Dear friend,
Today I've have an issue with the heat sensor during replacing the normal one by ex-proof one.
After replacing, the fire alarm controller got alarmed. Anybody faced this before please help.
Anything that can go wrong, will go wrong
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
Re: Sensor Issue
04/08/2011 4:26 PM
Probably the ex-proof sensor you put in is made to be used with a Zener Diode Barrier that won't give the same output as the non ex proof sensor you took out.
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
Re: Sensor Issue
04/08/2011 10:39 PM
Kwcharlie,
You are correct. The existing system has been operating without Zener Diode Barrier. While the contractor wanted to have a trial by replacing the new ex-proof without barrier, the main controller alarmed as if there was a fire in that zone. The new sensor manual suggested that it should be installed with the barrier to couple controller and sensor together.
I have requested them to disconnect the trial one from the system and reinstall the existing one. Still, the controller alarmed.
That zone now is disconnected to eliminate the false alarm.
Could you or anyone tell me what has been wrong here?
Re: Sensor Issue
04/09/2011 10:35 AM
Maybe going back and forth with different sensors that channel needs recalibration and/or setup? Also with all the work check the wiring and connections.
Think KISS [check visually; then check mechanically; last check electrically] and always check the last thing that was worked on first.
Re: Sensor Issue
04/09/2011 11:27 AM
This afternoon, the issue has been identified by a report that the contractor has mistaken in wiring. They had disconnected the signal wires without appropriate marking. Then they reconnected. The positive wire went into the negative pole of the detector and the controller made the false alarm.
Re: Sensor Issue
04/12/2011 7:19 AM
What has been wrong is that a hazardous area sensor and wiring wasn't installed in the first place!
Re: Sensor Issue
04/12/2011 8:22 AM
We share this idea. Cheer!
Register to Reply 6 comments
hien.nguyenquoc (3); kwcharlie (2); PWSlack (1)
