Previous in Forum: Waste To Energy   Next in Forum: New Nano-Cellulose Fibers
Gravity in Space
04/11/2011 9:15 AM
Hi, all
we should develop space ship equip with gravity will it ever posible, perhap another few year then.?
REgard's
Re: Gravity in Space
04/11/2011 10:32 AM
Why, at this time, would you do so?
Nearly all experiments done in earth orbit are done in space precisely because there is no gravity... well, there is a microgravity...
04/11/2011 3:25 PM
It can be done (working designs have been around for decades), but it just isn't economically feasible to do so for the small advantages it would provide.
Don't expect to see it with the increase in space tourism either, one of the main draws of space tourism is lack of gravity.
04/11/2011 6:45 PM
Simples...just spin it, as in 2001: A Space Odyssey.
(Or throw in a few tons of gravitons. )
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member Engineering Fields - Aerospace Engineering - Aeromarine Vehicle Engineer
04/12/2011 12:09 PM
Developing artifical gravity for long duration missions such as the space station and inter-planetary flight is a necessity.
The following is from
Man-Systems Integration Standards NASA-STD-3000, Volume I Revision B, July 1995 3.2.3.1 Microgravity Effects Design Considerations
{O}
The effects of weightlessness on human body size are summarized below and are discussed in greater detail in Figures 3.2.3.1-1 and 3.2.3.1-2. The primary anthropometry effects of microgravity are as follows:
Figure 3.2.3.1-1 Anthropometric Changes in Weightlessness
Parameter
Anthropometric change
Short-term mission (1 to 14 days)
Long-term mission (more than 14 days)
Pre vs. during mission
Pre vs. post-mission
Height
Slight increase during first week (~1.3 cm or 0.5 in).
Height returns to normal *R+O
Increases caused by spine lengthening
Increases during first 2 weeks then stabilizes at approximately 3% of pre-mission baseline. Increases caused by spine lengthening
Returns to normal on R+O
Circumferences
Circumference changes in chest, waist, and limbs. See Figure 3.2.3.1-2 for chest and waist changes. Changes due primarily to fluids shifts.
Mass
Post flight weight losses average 3.4%; about 2/3 of the loss is due to water loss, the remainder due to loss of lean body mass and fat. Center of mass shifts headward approximately 3-4 cm (1-2in.) See paragraph 3.3.7.3.2.1 for details.
Inflight weight losses average 3-4% during first 5 days, thereafter, weight gradually declines for the remainder of the mission. Early inflight losses are probably due to loss of fluids; later losses are metabolic. Center of mass shifts headward approximately 3-4 cm (1-2in).
Rapid weight gain during first 5 days postflight, mainly due to replenishment of fluids. Slower weight gain from R+5 to R+2 or 3 weeks.
Limb volume
Inflght leg volume decreases exponentially during first mission day; thereafter, rate of decrease declines until reaching a plateau within 3-5 days. Postflight decrements in leg volume up to 3%; rapid increase immediately postflight, followed by slower return to pre-mission baseline.
Early inflight period same as short missions. Leg volume may continue to decrease slightly throughout mission. Arm volume decreases slightly.
Rapid increase in leg volume immediately postflight, followed by slower return to pre-mission baseline.
Posture
Immediate assumption of neutral body posture(see paragraph 3.3.4)
Rapid return to pre-mission posture.
Reference: 16, Chapter 1, 208, pages 132-133 NASA-STD-3000 265
*Recovery day plus post mission days
a. Height Increase - Stature increases approximately 3%. This is the result of spinal decompression and lengthening.
b. Neutral Body Posture - The relaxed body immediately assumes a characteristic neutral body posture.
(Refer to Paragraph 3.3.4, Neutral Body Posture, for detailed information).
c. Body Circumference Changes - Body circumference changes occur in microgravity such as shown in Figure 3.2.3.1-2. These changes are due to fluid shifts toward the head.
d. Mass Loss - The total mass of the body decreases by 3% to 4%. This is due primarily to loss of body fluids and, somewhat, to atrophy and loss of the mass of muscles that were used in 1-G (muscle mass loss is dependent on exercise regimes).
Figure 3.2.3.1-2 Micro-gravity Changes in Height, Waist, and Chest Measured on Skylab Crewmen: One-G Measurements as Baseline
Reference: 16, Figure 19 and 20, pg. 1-28 and 29 NASA-STD-3000 266
You should check to see if similar data exists for the International Space Station
04/12/2011 6:15 PM
Thanks for the Good Answer rating
This just came out today from the National Academies of Science which is related to manned space exploration
It is a prepublication to
Committee for the Decadal Survey on Biological and Physical Sciences in Space; National Research Council; 2011; Recapturing a Future for Space Exploration: Life and Physical Sciences Research for a New Era; National Academy of Sciences; Washington, D.C. 20001;
The Preface states the following:
"In May 2009, the National Research Council's (NRC) Committee for the Decadal Survey on Biological and Physical Sciences in Space began a series of meetings initiated as a result of the following language in the explanatory statement accompanying the FY 2008 Omnibus Appropriations Act (P.L.110-61):
Achieving the goals of the Exploration Initiative will require a greater understanding of life and physical sciences phenomena in microgravity as well as in the partial gravity environments of the Moon and Mars. Therefore, the Administrator is directed to enter into an arrangement with the National Research Council to conduct a "decadal survey" of life and physical sciences research in microgravity and partial gravity to establish priorities for research for the 2010-020 decade."
You can download a free copy for your personal use by given your email address
http://books.nap.edu/catalog.php?record_id=13048&utm_medium=etmail&utm_source=National%20Academies%20Press&utm_campaign=NAP+mail+new+4.12.11&utm_content=Downloader&utm_term=
Doorman (1); Gannet (2); jack of all trades (1); Tornado (1)
