Previous in Forum: switching   Next in Forum: Halon Gas Alternative as Fire Suppression System
Power Systems
04/12/2011 2:35 PM
what are actually sequence components of current..i dint get the concept
cud anyone help me out???
Pathfinder Tags: sequence components
Good Answers: 244
Re: power systems
04/12/2011 3:38 PM
Good Answers: 445
Re: power systems
04/12/2011 3:39 PM
Physically, in a three phase winding a positive sequence set of currents produces a normal rotating field, a negative sequence set produces a field with the opposite rotation, and the zero sequence set produces a field that oscillates but does not rotate between phase conductors. Since these effects can be detected physically with sequence filters, the mathematical tool became the basis for the design of protective relays, which used negative-sequence voltages and currents as a reliable indicator of fault conditions. Such relays may be used to trip circuit breakers or take other steps to protect electrical systems.
Google on Symmetrical Components for more info.
Good Answers: 170
Re: power systems
04/17/2011 1:22 PM
Please read any good text book on Power System Analysis.
Register to Reply 3 comments
electricalexpert65 (1); msamad (1); RAMConsult (1)
