Previous in Forum: Cracking/ Deformation After Removal from Service   Next in Forum: Flanges Calculation
"Safe" Home Built Propane Burner for BBQ Smoker
04/12/2011 2:48 PM
Yes, I can imagine that this has been asked before on here but I'm fairly new. I am looking for DIY instructions for plumbing my homebuilt, 55gl smoker for a propane burner. Before I'm swarmed with responses suggesting that I buy a commercial one, I can't because I can't find one to fit right. Besides, I would really like to do it myself. I'm from TX and grew up seeing these all the time. Most had 1/2" black pipe with a series of holes along the length. Seems that each hole had a nice blue flame all the way up and down the pipe(s). Therefore I how it's possible.
I would assume that gas pressure, hole size, spacing and frequency are all important for both function and safety. So, can anyone lead me to info, or describe the variables I should be concerned with in order to build a burner system for this BBQ smoker? Again, I'm as much interested in learning how to do it as much as just having a safe and functional smoker.
Thanks!
Good Answers: 101
Re: "Safe" home built propane burner for BBQ smoker
04/12/2011 3:05 PM
Check here, here or here for some information.
Would a standard barbecue burner from a salvaged BBQ work?
Or just google your question.
Good Answers: 1693
Re: "Safe" Home Built Propane Burner for BBQ Smoker
04/12/2011 3:49 PM
Judging by this, I'd say small holes are in order. I'd probably go with 1/16" or smaller to sstart. The picture came from:
Cast Burners, Pipe Burners. High Heat Cast Iron Propane Burners ...
Now, if I were doing it, I'd use wood and forget the gas. You DO live in Texas, after all!
Seriuosly, smokers usually have the heat in one end and use indirect heat for slow cooking the meat so the burner from a grill might work.
You might try some of the BBQ forums too.
Sorry I couldn't be of more help, but I've never had anything but a wood burning cooker at my house.
BTW, my Texas cousin built a wood burner out of 36" oil well casing that was 10 feet long and mounted on dual axles.
04/13/2011 6:59 AM
Everything in Texas is bigger...
And I agree. What self respecting BBQ connoisseur would use gas?
Build your fire box in one end and make it smokey!!!
Johannes
04/13/2011 7:30 AM
Here's a pic of my smoker. I think I may have made the orifice a tad to large.
04/13/2011 8:44 AM
All i want to do is sell propane and propane accessiories.
(Hank Hill)
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Good Answers: 16
04/13/2011 10:02 AM
True barbeque smokers don't need high Btu output, just enough heat to make the wet wood smoke. Something on the order of a small gas stove burner or a propane camp stove is about right. The type of homemade burner you are talking about are high pressure, high Btu output burners used for fish and turkey friers that need to heat and maintain oil at temperatures of 350+ degrees F. Most smokers only run 180 to 240 degrees F. You can buy low pressure burners for about $15+ S/H from Agri Supply, but if I were you I would instead use an eye element from an electric stove. You can rig it with a relay controlled by a settable/programmable digital thermometer sold at most big box hardware stores. You then will not have to be watching the smokebox temp and adjusting the propane burner to maintain your temp. Also, propane burners generate moisture and some people can detect a taste from the combustion by products. Meats smoked for four to eight hours may experience this. Not a problem with electric heat. Use oak, pecan or apple wood chunks or sawdust for best results. Mesquite and hickory may be a little strong for long term smoking.
04/13/2011 1:03 PM
Thanks Greycav.
I'll have to look into the eye electric option. Never thought of that. I hear what you're asying about the amount of heat needed for smoking. I did however fail to mention that I want my smoker to be duel purpose. I'd like to have the option of using it as a grill too. Hence the flame. Maybe I rig it with both the eye and a propane set up??
Thanks again.
Register to Reply 7 comments
Fredski (1); Graycav (1); Johannescnc (1); lyn (1); ronclarke (1); RVZ717 (1); weldeng449 (1)
You might be interested in: Gas Heaters and Propane Heaters, Burners, Fireplaces
