Previous in Forum: Electrical Commissioning Engineer, Power Plant   Next in Forum: Relay
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Electrical, Water, Gas Pipes Separation
04/17/2011 5:19 AM
Well, if we have all these pipes installed in parallel, which separation space (in SI unit) should be enough according to NEC, BS, or IEC standards? And how is the installation configuration?
Anything that can go wrong, will go wrong
Good Answers: 181
Re: Electrical, Water, Gas Pipes Separation
04/17/2011 9:23 AM
300mm for metering installations according to BS7671 as for pipe runs it doesn't give a specific mesurement.
Good Answers: 170
04/17/2011 12:26 PM
Minimum seperation distance of 300mm between any pipeline and an electric cable. Configuratioin could be vertically parallel or Horiozontally Parallel or Vertcally Crossing or Horizontally Crossing
04/23/2011 9:07 AM
EE65, I know it would be vertical or horizontal crossing but how it would be when in vertical?
1. Gas? as top layer
2. Power? as second layer?
3. Water? as first layer
Or how?
Register to Reply 3 comments
electricalexpert65 (1); hien.nguyenquoc (1); TonyS (1)
