Previous in Forum: Electrical, Water, Gas Pipes Separation   Next in Forum: Improving Earthing
8 comments
Relay
04/17/2011 7:38 AM
suppose i kept the time setting of 400/5 overcurrent relay as .2 and overcurrent setting as 75%. then if fault current arives then after how many seconds the relay will operate???????????????
plz answer this .........
Re: Relay
04/17/2011 9:07 AM
This depends on the specific overcurrent relay you are using.
You have to find the manufacturer's information for that relay and the time / current curves supplied there.
Good Answers: 181
Re: Relay
04/17/2011 9:16 AM
Not enough information.
It also sounds like you need to increase the time setting you allocate to your homework!
Re: Relay
04/17/2011 12:14 PM
Unfortunately, this guy appears to have a job.
Improving Earthing
Makes ya wonder what he did in class, doesn't it?
Re: Relay
04/17/2011 10:57 AM
thankx a lot for ur good comments......................
but if we will use normal inverse curve then what will be the time after which relay will operate???????????
thankx.
Re: Relay
04/17/2011 12:12 PM
There is no "normal" inverse curve that applies to all devices. You have to get the curve for the specific device you have, from the manufacturer.
If this is homework or a learning / practice situation and a specific device has not been mentioned, then I'd suggest you get the curve for any device, use it, and in your answer specify that your answer is based on the curve for such and such a device.
One of the other posters posted links to some curves for some specific devices for a specific manufacturer.
Re: Relay
04/19/2011 3:30 PM
Please describe the curve that is in use.
Good Answers: 170
Re: Relay
04/17/2011 12:24 PM
It depends upon:
i) The type of tripping charecteristics you have selected in the relay (viz) Definite Time or Inverse Time and even within inverse-time, what is the slope - Normally Inverse or Very Inverse or Extremely Inverse or Long Time Inverse, etc.
ii) The acutal magnitude of the fault current
Re: Relay
04/17/2011 12:35 PM
Although I don't usually vote a GA for responses that are links to other people's work, I feel that the two articles you cited were to the point and appropriate to the OP's level of understanding.
He would do well to take your advice seriously, and seek it in the future.
Register to Reply 8 comments
electricalexpert65 (1); lyn (2); mir imran altaf (1); PWSlack (1); rhkramer (2); TonyS (1)
