Previous in Forum: Securing Low Voltage Wires With Compression   Next in Forum: AFBC
KSB PUMP
04/18/2011 11:58 PM
WHAT IS THE MEAN OF KSB 65/14 PUMP MODEL
Re: KSB PUMP
04/19/2011 12:29 AM
Good Answers: 97
Re: KSB PUMP
04/19/2011 2:42 AM
It is just a pump model number.
The 65 indicates the size of the outlet.
KSB changed their numbering system looooong ago (I don't have the latest info at hand)
The first thing that comes to mind is KSB WKL 65/14 - that would be a 14 stage 65 mm pump. (I however doubt if that was ever made )
I think 14 stages was made in the WKH range. (14 stage high pressure.)
It could also be a KSB ETA 65/14 - That would be a low pressure pump (but I cannot recall it)
It could also indicate a 14 stage submersible.
Please supply more info!!!!!
Re: KSB PUMP
04/20/2011 4:37 AM
THANKS FOR CONFIRMING ME
BUT DO U KNOW H D A
Good Answers: 97
Re: KSB PUMP
04/20/2011 9:09 AM
The HDA series is a high pressure boiler feed pump (I think in the vicinity of 950m for the 14 stage)
Your pump supplier or KSB itself will have the best information available.
On the WKL series the 65 mm was the odd size out with the 80mm usually affording better performance at most duty points. If you need to replace you must at least compare the 65 with the 80.
Good Answers: 97
Re: KSB PUMP
04/19/2011 9:45 AM
It may refer to the KSB WKF 65/14 (not WKH) 14 Stage 65 mm pump
http://www.ksb.com.pk/high.htm
Hendrik (3); lyn (1); SATYAVEER (1)
