Previous in Forum: VFD cable   Next in Forum: Exact Derating Factor
Info require about FIX HMI Software
04/19/2011 2:38 AM
Dear Sir,
I want to communicate one machine PC (having FIX HMI) with another HMI of a PC (and then PLC) to get some data from FIX HMI. For this reason, I want to know if "Fix HMI" is OPC compliant or not? Or some body tells me how to check it?
Good Answers: 804
Re: Info require about FIX HMI Software
04/19/2011 1:59 PM
"Fix" was an old HMI product sold by Intellution, who was subsequently bought by GE in 2002. So if what you have does not say GE on it, it is older than 2002 and not likely OPC compliant.
Good Answers: 204
04/19/2011 11:00 PM
OPC
try checking with http://www.opcfoundation.org/ if you can't find out any other way.
Good Answers: 176
04/28/2011 9:24 PM
OPC DA has been in use since the mid '90's and there is some chance that an old Fix version might be an OPC client.
I have a recollection of helping a client setup his then-dated version of Fix in about 2003 or 2004 (?) and it was running as an OPC client.
I can't recall where the OPC setup in Fix was, but poking around the help files will probably lead to some reference to OPC the version had any OPC capability.
Register to Reply 3 comments
chrisg288 (1); Iris (1); JRaef (1)
