Previous in Forum: Cavalier 2004 Manual Trans Starter Location   Next in Forum: Bad Gasoline?
13 comments
mr
04/19/2011 6:11 AM
my challenge is how to remove turtleshell polish from auto glass so far have tried solvent, scraping with razor blade, glass cleaner, jewelers rouge, meths and hot water hope someone has a brainwave
Re: mr
04/19/2011 7:04 AM
Try straight household ammonia. I know it works to remove furniture wax prior to refinishing.
Re: mr
04/20/2011 4:55 AM
Found a cheap source of ammonia same one as i use on the lemon tree, works well on the windscreen, thanks for your help
Re: mr
04/20/2011 7:29 AM
Sure. Thanks for reminding me. I need some today to remove furniture polish before refinishing.
Re: mr
04/19/2011 9:26 AM
What is turtleshell polish? Polish made from turtle's shells?
Good Answers: 58
Re: mr
04/19/2011 12:09 PM
Um, maybe not made from turtle shells but what you use to polish turtle shells
Re: mr
04/19/2011 12:59 PM
I didn't know that turtles had to be polished.
See, I learned something on CR4 today.
Good Answers: 58
Re: mr
04/19/2011 10:03 AM
Try Acetone.
Apply it to a cotton cloth.
Rub Acetone onto effected area.
Use it very sparingly.
Do not apply in direct sunlight.
Apply to cool glass (no more than 80 Degree F)
Keep it off of painted surfaces.
Rinse immediately with cool water, wash with dish detergent.
Rinse again with liberal amounts of cool water.
Where run-off contacts painted surfaces, wash down with dish detergent also and rinse.
Re: mr
04/19/2011 1:48 PM
Use automotive clay. It has the consistency of play-doh. It is used on your cars paint to clean it thoroughly. I'm sure it will work on your glass as well. You can pick it up at any automotive store. You will also need an oil to go with it. You can usually find it in a kit. To see if you need to use it on your paint you can use the baggy test. With you hand inside a zip lock bag gently rub your hand over the paint. If it feels rough you should use clay on it. The clay will pick up all of the dirt and grime that normal washing can't get. Just a tip: If you drop it on the floor just throw it away (unless you want to scratch your car up).
"It's not the dress that makes you look fat. It's the fat that makes you look fat." - Al Bundy
Re: mr
04/19/2011 4:49 PM
use a sos pad or steel wool with regular dish soap
Re: mr
04/19/2011 5:53 PM
You are kidding, right. How could you possibly advise anyone to scrub glass with a metal abrasive pad?????????????????????
"polish from auto glass"
Re: mr
04/19/2011 8:35 PM
auto glass is tempered and wont scratch have been detailing cars and trucks for years
Re: mr
04/19/2011 8:44 PM
OK,
I'll take your word for it. I won't report back because I'm not going to test my windshield to find out.
Good Answers: 97
Re: mr
04/20/2011 1:15 AM
I think I see a pattern here, nah is the bottom of the bottle......
Anonymous Poster (1); badluck1010 (2); bwire (1); KJK/USA (2); kramarat (2); lyn (4); thall (1)
