Previous in Forum: High Temperature of Thrust Bearing of Steam Turbine   Next in Forum: Frequent Startup/Shutdown Effects on Fertilizer Plant Equipments
Static Pressure Calculation
04/21/2011 4:59 AM
How to calculate the static pressure of axial exhaust fan given the cfm for a chlorine room
Re: Static Pressure Calculation
04/21/2011 7:19 AM
Why calculate <rhetorical question>? Look it up in the manufacturer's performance chart.
04/21/2011 7:40 AM
This is a rather complex question, depending largely on the size and shape of openings (including miscellaneous leaks/cracks) through which the air will be moved.
If I couldn't find a governing standard, I would "wild guess" 3/8 inch (~10 mm) water column for this duty. (And, because it is a wild guess, I would be prepared to be overruled.)
Register to Reply 2 comments
