Previous in Forum: Halon Substitute   Next in Forum: Methanol Purging
12 comments
Humorous and Unique Engineering Conversation Table
04/21/2011 9:36 PM
I received this in an email. I don't know where it originated, but thought this group might enjoy it. Can you think of others?
1) Ratio of an igloo's circumference to its diameter = Eskimo Pi
2) 2000 pounds of Chinese soup = Won ton
3) 1 millionth of a mouthwash = 1 microscope
4) Time between slipping on a peel and smacking the pavement = 1 bananosecond
5) Weight an evangelist carries with God = 1 billigram
6) Time it takes to sail 220 yards at 1 nautical mile per hour = Knotfurlong
7) 16.5 feet in theTwilight Zone = 1 Rod Serling
8) Half of a large intestine = 1 semicolon
9) 1,000,000 aches = 1 megahurtz
10) Basic unit of laryngitis = 1 hoarsepower
11) Shortest distance between two jokes = A straight line
12) 453.6 graham crackers = 1 pound cake
13) 1 million-million microphones = 1 megaphone
14) 2 million bicycles = 2 megacycles
15) 365.25 days = 1 unicycle
16) 2000 mockingbirds = 2 kilomockingbirds
17) 52 cards = 1 decacards
18) 1 kilogram of falling figs = 1 FigNewton
19) 1000 milliliters of wet socks = 1 literhosen
20) 1 millionth of a fish = 1 microfiche
21) 1 trillion pins = 1 terrapin
22) 10 rations = 1 decoration
23) 100 rations = 1 C-ration
24) 2 monograms = 1 diagram
25) 4 nickels = 2 paradigms
26) 2.4 statute miles of intravenous surgical tubing at
Yale University Hospital = 1 IV League
27) 100 Senators = Not 1 decision
J B
Good Answers: 83
Re: Humorous and Unique Engineering Conversation Table
04/22/2011 9:11 PM
04/22/2011 9:22 PM
Here's one:
1. All pipe is to be made of a long hole, surrounded by metal or plastic centered around the hole.
2. All pipe is to be hollow throughout the entire length - do not use holes of different length than the pipe.
3. The I.D. (inside diameter) of all pipe must not exceed the O.D. (outside diameter) - otherwise the hole will be on the outside.
4. All pipe is to be supplied with nothing in the hole so that water, steam or other stuff can be put inside at a later date.
5. All pipe should be supplied without rust - this can be more readily applied at the job site. N.B. Some Vendors are now able to supply pre-rusted pipe. If available in your area, this product is recommended as it will save a lot of time on the job site.
6. All pipe over 500ft (153m) in length should have the words "long pipe" clearly painted on each end, so the Contractor will know it is a long pipe.
7. Pipe over 2 miles (3.2km) in length must have the words "long pipe" painted in the middle, so the Contractor will not have to walk the entire length of the pipe to determine whether or not it is a long pipe.
8. All pipe over 6" (152mm) in diameter must have the words "large pipe" painted on it, so the Contractor will not mistake it for small pipe.
9. Flanges must be used on all pipe. Flanges must have holes for bolts quite separate from the big hole in the middle.
10. When ordering 90 degrees, 45 degrees or 30 degrees elbow, be sure to specify right hand or left hand; otherwise you will end up going the wrong way.
11. Be sure to specify to your vendor whether you want level, uphill or downhill pipe. If you use downhill pipe for going uphill, the water will flow the wrong way.
12. All couplings should have either right hand or left hand thread, but do not mix the threads - otherwise, as the coupling is being screwed on one pipe, it is unscrewed from the other.
Good Answers: 243
04/22/2011 11:17 PM
Lyn, that length of hole business makes me wonder, why can't the inside of a pipe be larger than the outside.? I was out the other day and i saw a gal start unloading her purse and it was clear that the purse was bigger on the inside than the outside. Why can't we do that with pipe?
Milo
Good Answers: 83
04/22/2011 11:21 PM
That kind of engineering takes on a whole new dimension.
Good Answers: 130
04/22/2011 11:38 PM
I'd ask the OP that one
04/23/2011 7:45 AM
Of course it can be done with pipe. Just look at the inside of my blue phone box (also known as a TARDIS (Time And Relative Dimensions In Space). As anyone knows, it's bigger on the inside than the outside.
J B
04/23/2011 9:03 AM
Milo,
You're confusing the practical with the occult. No man will ever understand what goes on inside a woman's purse, nor why she could possibly think she might need all that stuff. That's a dimension unto itself.
Lyn
Good Answers: 243
04/23/2011 9:18 AM
Perhaps, But you do not deny that it is so accomplished. Why can't us mere engineers develop similar dimensional transcending technologies?
Milo
Good Answers: 114
04/23/2011 10:16 AM
Speaking of Transcendian
Good Answers: 243
04/23/2011 12:42 PM
Ahh, thanks for this. Will download this on my Ipad Kindle app.
Good to see him get this project completed!
Milo
India - Member - New Member
Good Answers: 164
04/24/2011 11:59 AM
1 million microphones = 1 phone
04/24/2011 5:31 PM
10 comedians = 1 decacards
100 fast-moving centipedes = 1 velocipede
1 trillion picoboos = a ghostly exclamation
Register to Reply 12 comments
34point5 (1); Garthh (1); JBTardis (1); kvsridhar (1); lyn (2); Milo (3); sue (2); Tornado (1)
You might be interested in: Label and Nameplate Services, Glass Tiles, Cement Tiles
