Previous in Forum: Reducing Torque Load of Spot Welding Machines   Next in Forum: XLPE Cable
Medium Voltage and Low Voltage Cable
04/22/2011 2:31 AM
hello, I just need to know please why medium voltage cables are usually 3 core ones (without neutral and earth cores) and why low voltage cables as outgoing of secondary of transformers are withoutearth core?
Re: Medium Voltage and Low Voltage Cable
04/22/2011 2:38 AM
Is this really true?
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
04/22/2011 5:01 AM
This is 4-core underground MV cable sample.
The earthing wire coming out from transformer secondary side normally is from the transformer frame. (where this earth point can be internally or externally connected to neutral point inside the transformer). So, you will not see they are coming out at the same level with the other cables since the connection points normally is near the bottom of the transformer.
Anything that can go wrong, will go wrong
04/23/2011 7:49 AM
dear,
Why working with prejudiced mind ?
You just ask for the cables suitable for the supply mains. - wether 3 phase 3 wire, 3 phase 4 wire or 3 phase 5 wire ?
Exploring the Science of Electricity
Good Answers: 170
04/25/2011 7:17 AM
It all depends upon what is the type of the network - TN (TN-C or TN-S or TN-C-S) or TT or IT.
electricalexpert65 (1); harry potter (1); hien.nguyenquoc (1); Tornado (1)
