This was suggested to me and I did a small test and it worked better than I expected. Basically the idea is to have a bundle of small diameter tubes doing airlift with very low pressure. In my case, I was using only enough pressure to push air about a meter deep in water and it easily pumped to 13 ft high.
I havn't any place that is significantly higher so I don't have a way of finding the limit. This type of airlift is by plug flow, so it works differently than normal airlift pumps. If the bundle of tubes idea can pump from fairly deep with only 3 ft of submergence, then it might be an option for people in poor countries. The tubes might be relatively expensive? but airlift pumps are robust and low pressure air could be produced easily in a number of different ways. Even bellows could do it. Maybe even slow pumping all day with a solar panel producing the power?
Video is at http://www.youtube.com/watch?v=lKtB1YKoMxk
I would appreciate it if anybody did this (Mabye someone can check if it pumps to 20 30 or 40 ft high) ? It is a pretty cheap experiment.
Thanks Brian
