Previous in Forum: Improper Ductwork Approved?   Next in Forum: Bending Machine
Grab Ship Unloader Manual
04/24/2011 3:35 AM
we have a grab ship unloader (for unloading coal) that purchase from china. but it has no proper operation manual. frequently grab lifting/closing steel cables are ejecting from pulleys and operators are hitting the bottom of the barge. i need to find a solution for these problems. pls help me
Re: Grab ship unloader manual
04/24/2011 4:05 AM
Can you show a picture or drawing of the pulley design?
Good Answers: 181
Re: Grab Ship Unloader Manual
04/24/2011 3:19 PM
Basic training of the drivers springs to mind.
With a grab crane as the load is transferred from the boat the load level drops. No mater what you do you will never set limits for the load level, it's all down to the driver to be vigilant and competent. The only limits that are practical are top limit and the lower/open differential. If the grab reaches the load lever at speed it will throw the ropes.
My best suggestion would be employ two burly fitters to re-reeve the ropes and then persuade the driver to be careful (or else)!
04/29/2011 9:08 PM
i will put some photos. we fix a roller shaft above to the pulley. then the rope will not be ejected from the pulley. please tell me "what is burly fitter"? i haven't heard it.
Good Answers: 130
04/30/2011 2:24 AM
Installing extra pulleys may just see cables jammed, kinked or sheared.
What Tony is saying is train your operators, as only abuse, or lack of skill sees cables 'ejected'.
A grab bucket has self digging geometry.
Dropping them (to get a bigger dig) is pointless, dangerous and damages things (including bucket teeth and hinge geometry).
Is it perhaps this one?
The technique is to lower the open grab onto the material, relax lift slightly, close the bucket, and raise the load.
A "burly fitter" is a like large muscled mechanic, but generally less happy, especially about having to fix 'stupidity'.
Register to Reply 4 comments
34point5 (1); ruchiraslk (1); TonyS (1); Tornado (1)
You might be interested in: Manual Valve Actuators, Manual Pulse Generators, Hooks
