Previous in Forum: Grab Ship Unloader Manual   Next in Forum: Efficiency of ORC Power Generation
16 comments
Bending Machine
04/24/2011 8:35 AM
what is diameter
Re: bending machine
04/24/2011 8:37 AM
2 x radius
Re: Bending Machine
04/24/2011 8:46 AM
There are two types of diameter. Inside, and outside.
In pipe, the inside diameter contains the hole. The outside diameter is where the pipe stops. To make pipe, you would need a third dimension, length. Anything under a certain length, depending on diameter, would be considered a washer and would not be suitable for use as a pipe.
Hope this helps.
Just in case, I'll include this graphic from Wiki:
If this pipe were buried, the dirt would go on the outside, where it says CIRCUMFERENCE.
Re: Bending Machine
04/24/2011 9:00 AM
Nice job on the self restraint. I know that must have been difficult.
Re: Bending Machine
04/24/2011 9:07 AM
I did it for the Easter Bunny.
Good Answers: 179
Re: Bending Machine
04/24/2011 10:03 AM
LOL you guys kill me! LOL
I don't think I'll proceed any further.....I may not be nice in my response to the OT's question (basic Elementary school learning IMO).
Happy Easter to all!
India - Member - New Member
Good Answers: 164
Re: Bending Machine
04/24/2011 10:53 AM
Let's have some constructive fun while we are trying to figure out what the OP wants.
There is a sphere, diameter not known. A through-hole is drilled through it, a diameter being its axis, hole diameter not known. The only thing known is that the length of the hole is 6". Question: What is the volume of material which is left ? Some images to help.
If you know the answer, please wait for us mere mortals to work it out, please, thanks.
Re: Bending Machine
04/24/2011 3:10 PM
It can be done with calculus.
But calculus isn't necessary; there is a geometric solution.
There is also a trick that makes simple arithmetic enough.
This could be a good Newsletter Challenge.
Re: Bending Machine
04/24/2011 3:31 PM
There is also a trick called solid modeling.
Re: Bending Machine
04/24/2011 3:37 PM
Ah, yes, the desk jockey method.
However, the number 113.1 sort of loses its geometric meaning.
Re: Bending Machine
04/24/2011 6:58 PM
Bin out 'minding' my Small all night - sure I could crack it, will have a go in the morning. Please don't give it away too soon.
Re: Bending Machine
04/24/2011 10:52 PM
I trust "Cavalieri's Principle" will not be too big a giveaway. (Nor Archimedes' Method of Exhaustion.)
Good Answers: 130
Re: Bending Machine
04/25/2011 1:16 AM
I once had a napkin ring 6.00 diameter but the idiots forgot the hole.
Good Answers: 130
Re: Bending Machine
04/25/2011 1:23 AM
Do you mean what is the standard bend radius in sheet metal?
If so, r = 2T
(see 1 for further computations required)
Good Answers: 164
Re: Bending Machine
05/04/2011 11:33 PM
Whatever happened to this thread? With those clever clues from Tornado and 34.5, i looked forward to a spate of Ah...so that's it! responses. Well, some pan out, some peter out i guess
Good Answers: 130
Re: Bending Machine
05/04/2011 11:49 PM
Why not re-post in it's own right.
(This thread is probably a bit 'specialist' for the usual suspects)
Good Answers: 164
Re: Bending Machine
05/04/2011 11:55 PM
Knowing the mathematical calibre of some CR4 members (you both included), i would leave that to one of you, which is the right thing to do. Not this sphere/hole thing, maybe something much more elegant perhaps .....
Reply to Forum Thread 16 comments
34point5 (3); CaptMoosie (1); JohnDG (2); kramarat (1); kvsridhar (3); lyn (3); Tornado (3)
