I know voltage drop has been kicked around quite a lot, but I would like to get some views on this thought. I'm working on a 1/2 hp pump, 5 amp, single phase, 230v., three wire, 160 ft. in well. Power source is 3300 ft. from well. Just using simple voltage drop calculations and using 7000 ft. of run I figure a #4cu. would work. Now what if I used a couple of 2:1 transformers as a step up and then step down and the motor controller at the well head. The questions are: what size copper wire would work? how does voltage drop affect the primary voltage at the step up transformer? would reactance from the transformers affect the three wire motor controller? should I be looking at starting current instead of FLA, the motor will be starting with quite a load( would the motor ever start with say a #10 cu.) Is there anything else I'm overlooking? Thanks
