Previous in Forum: How to Get Data From an HMI to Another PC   Next in Forum: Power Distribution Network Simulator
17 comments
Single Core Parellel Conductor Current Balance
04/28/2011 10:11 AM
Hello,
at the below picture, you can see my installation. Now sysytem is starting to work. Beginning current is less than nominal current, you can see below table. Cable length, cable cross-section, cable manufacturer, cable termination system are the same. Cable laying on the cable tray. Cable cross-section is 120mmsquare
Do you have any idea why is the current different between cables and what can I do for balance the current?
Regards
Cable
Current
L1-16,711%
L1-27,712%
L1-35,28%
L1-44,57%
L1-54,47%
L1-63,35%
L1-72,84%
L1-83,76%
L1-94,27%
L1-109,715%
L1-11610%
L1-124,77%
Total
62,9
Re: Single core parellel conductor current balance
04/28/2011 10:24 AM
Just to get my head on straight, I had to convert 120 mm square to AWG or similar--iiuc, thats close to 250 MCM. That's a lot of copper (or aluminum).
Does each of those cables have 3 insulated cores of 120mm square conductor?
I suspect that because of the arrangement of cables, each "core" sees a pretty significant difference in impedance.
If the cables do each have 3 insulated cores, I'd seriously consider running one each of L1, L2, and L3 in each cable.
Then I'd try to locate the N (neutral) cables more centered with the L1, L2, L3 cables located as symmetrically as possible around the neutral. (I'm not sure how important this is, or how much effect doing this would have.)
If the cables do not have 3 insulated cores, I'd try to relocate each cable to make a more symmetric arrangement, with transitions at intervals along the cable tray where I switch a cable from one location to another--all of this aimed at trying to keep the impedance the same.
How much current is in the N (neutral)?
7
Good Answers: 140
04/28/2011 10:37 AM
You have setup the cables in just about the worst possible arrangement for inductive reactance to cause impedance differences in the cables to cause a imbalance of current flow.
You need to think about rearranging the cables into...
Bundles of 4 conductors, each bundle to consist of "1 L1 + 1 L2 + 1 L3 + 1 N". Each bundle should be separated by at least two cable diameters.
You might want to take a look at the Appendix B notes to CEC rule 12-108 for more info.
04/28/2011 12:50 PM
Good answer (better than mine).
After I read yours I went looking for the CEC on line. Didn't find it, but found this, which gets quite deep, but might be worth the OP's time to at least skim:
A CABLE CONFIGURATION TECHNIQUE FOR THE BALANCE OF CURRENT DISTRIBUTION IN PARALLEL CABLES
Good Answers: 244
04/28/2011 7:13 PM
The answers from both "North of 60' and "rhkramer" are good. CEC (C22.1-09) Appendix B (notes to rule 12-108 and rule 4-008) clearly illustrates this topic with figures.
While NEC simply applies the condition for single conductor installation in article 392.8(D) which is
"Where single conductor cables comprising each phase, neutral, or grounded conductor of an alternating-current circuit are connected in parallel as permitted in 310.4, the conductors shall be installed in groups consisting of not more than one conductor per phase, neutral, or grounded conductor to prevent current imbalance in the paralleled conductors due to inductive reactance. …"
This previous thread also may help: http://cr4.globalspec.com/thread/41241/Laying-of-Multiple-Cables-for-Each-Phase
- MS
Re: Single Core Parallel Conductor Current Balance
04/28/2011 4:06 PM
Oh boy, as per comments in post #2 above you need to change your terrible cable configuration, quick!
Re: Single Core Parellel Conductor Current Balance
04/28/2011 9:36 PM
I couldn't find L4, L5,..., L12 in the picture, which is a weird layout, anyway; as already noted.
04/28/2011 11:15 PM
If you look at any one of the cables (in the picture) it looks like they are each a 3 conductor cable. There are 4 such cables for each phase (L1, L2, and L3) and the neutral. So that (I believe) is how he gets L1-1 thru L1-12, and likewise for the other phases. His table only shows the currents fro L1.
Good Answers: 140
04/28/2011 11:59 PM
From his drawing, I understood that he had 12 single conductor 120 sq/mm conductors.
04/29/2011 7:02 AM
Well, I guess he (the OP, muratdeli) needs to tell us. My clues were the table with L1-1 thru L1-12 and the three circles in an equilateral triangle spaced across the cable tray.
If he does come back and respond, I'd like to also know what the units of current are--he has percents, and then currents that look like they are very low.
I mean like 6,7; 7,7; 5,2, ...--are those 6.7, 7.7, 5.2, ... amps?
Good Answers: 140
04/29/2011 9:52 AM
Agreed... I am pretty sure those are amps. In some languages, it is common to use a comma instead of a decimal to indicate a number like 6.5.
He more then likely put a small load (was not the total in the 65 amp range) on the parallel sets to check the distribution of current. Good thing he did so, if he were to load this setup to its design loading, the inductive reactance and the current imballance would be far worse then what he presented to us in his only post (hey there OP... join the conversation or we will drop it).
Given the imballance shown with only 60 some odd amps of loading... a failure in one or more of these conductors, once loaded at desing amperage, is a real possibility.
Sounds to me like the engineer of record for this project needs his head shaken and his arse booted. It is clear, IMHO, that the EE on this job needed to have ensured that the installation contractor was aware of the need to arrange the cables in the tray properly.
As well, given the load this setup was meant to carry, why was not bus duct specified?
04/29/2011 11:23 AM
Good point--yes, that was probably a small test load.
04/30/2011 5:37 PM
Dear North of 60, thank you for your all response. Sorry for my late answer I try to solve my problem. I'll add a new post and describe my new stiuation.
04/30/2011 5:30 PM
Dear Rhkramer, thank you for your all response and sorry for my late answer as you see I have a big problem and try to solve.
Yes 6,7 mean is 6.7 amps and total current is very low now.
Good Answers: 32
04/29/2011 12:02 AM
None of the cable pair used by you are identical. Looks like they are not of standard grade.
Good Answers: 80
04/30/2011 1:25 PM
You are all assuming that the line voltages are equal and that the load is balanced. They are more likely the cause for the current imbalance.
The OP should use a good meter to verify the line voltages and re-connect the load on different phasing to insure that the imbalance is really from the cable layout.
04/30/2011 7:05 PM
First thank you for all good comment and sorry for my late answer. I have three installed line. First at the upstream and it is 230 meter long. May be the best way is the bus duct application. But it is not very practical according to site conditions.
2. and 3. lines are between transformer and LV distrubition panel. They are 24 meter long.
2. and 3. lines conductor are the same. Single core 120 sq/mm copper.
You can see below picture and table how are the currents before and after your comments. All values are measured by 2 clamp meter and total measure period for 1 group 5-10 min.
As you see you are right 1 L1 + 1 L2 + 1 L3 + 1 N better then mine
I want to ask a new question. All currents are very small at now but later increase to nominal current. At now (small current) there are %5(for example) difference between two conductor when the currents increase what about the ratio?
Regards
TR1
Total Power(kW)
Length(m)
Cable/Ph
Nominal Current
Per Cable
Current(A)
Cable Capacity(A)
14402482312,14289,02308
BEFORE
AFTER
Cable
Current(A)
(measured)
Ratio to total current
At Nominal Current(A)
Cable
Current(A)
(measured)
L1-1136%137,88L1-122,413%304,66
L1-2167%169,70L1-223,514%319,62
L1-3146%148,49L1-319,511%265,22
L1-42813%296,97L1-422,613%307,38
L1-52813%296,97L1-517,510%238,01
L1-64320%456,06L1-62112%285,62
L1-73014%318,18L1-719,511%265,22
L1-84621%487,88L1-82414%326,42
Total
218
2312,14
Total
170
2312,14
Cable
Current(A)
(measured)
L2-119,513%309,24
L2-223,316%369,50
L2-317,712%280,69
L2-416,812%266,42
L2-51812%285,45
L2-62014%317,17
L2-715,310%242,63
L2-815,210%241,05
Total
145,8
2312,14
Cable
Current(A)
(measured)
L3-11511%260,18
L3-217,313%300,08
L3-319,615%339,97
L3-416,512%286,20
L3-516,512%286,20
L3-616,112%279,26
L3-714,111%244,57
L3-818,214%315,69
Total
133,3
2312,14
TR2
Total Power(kW)
Length(m)
Cable/Ph
Nominal Current
Per Cable
Current(A)
Cable Capacity(A)
9002451445,09289,02308
BEFORE
AFTER
Cable
Current(A)
(measured)
Cable
Current(A)
(measured)
L1-11815%216,76L1-13525%366,51
L1-21815%216,76L1-22619%272,26
L1-33630%433,53L1-32720%282,73
L1-42420%289,02L1-42317%240,85
L1-52420%289,02L1-52720%282,73
Total
120
1445,09
Total
138
1445,09
Cable
Current(A)
(measured)
Cable
Current(A)
(measured)
L2-11915%212,84L1-13019%269,27
L2-22519%280,06L1-23220%287,22
L2-33225%358,47L1-33019%269,27
L2-42116%235,25L1-43421%305,17
L2-53225%358,47L1-53522%314,15
Total
129
1445,09
Total
161
1445,09
Cable
Current(A)
(measured)
Cable
Current(A)
(measured)
L3-11821%298,98L1-13120%294,72
L3-22428%398,64L1-23020%285,21
L3-31315%215,93L1-33020%285,21
L3-41618%265,76L1-42617%247,19
L3-51618%265,76L1-53523%332,75
Total
87
1445,09
Total
152
1445,09
Good Answers: 140
05/01/2011 3:18 AM
I think you are cutting it a little to close.
The amount of inductive reactance will increase as the current increases. It is not a straight ratio from your test to what the cables will see when under full load.
You may want to think about adding one more set of conductors to the parallel runs. I would.
Register to Reply 17 comments
jack of all trades (1); marcot (1); msamad (1); muratdeli (3); North of 60 (4); rhkramer (5); Shyam (1); Tornado (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
