Previous in Forum: Japanese Semiconductor Replacements   Next in Forum: Speed Sensors
Transformer / HT Motor
04/29/2011 10:16 AM
1.IN DELTA/DELTA POWER TRANSFORMER WHAT TYPE VECTORGROUP WE HAVE TO SELECT & WHY?
2..IN STAR/STAR POWER TRANSFORMER WHAT TYPE VECTORGROUP WE HAVE TO SELECT & WHY?
3.IN DISTRIBUTION TRANSFORMER DELTA/STAR DYN11 WILLBE THERE. INSTEAD OF DYN11 WHAT TYPE OF VECTORGROUP YOU WILL SELECT & WHY?
4.IN DELTA/DELTA POWER TRANSFORMER HOW YOU TAKE NEUTRAL?
5.WHAT IS DIFFERENT BETWEEN OVERLOAD AND OVER CURRENT?
6.WHAT IS DIFFERENT BETWEEN JAM TRIP AND LOCKED ROTOR CURRENT TRIP?
7.WHAT IS DIFFERENT BETWEEN OVERLOAD AND LOCKED ROTOR CURRENT TRIP?
8. WHAT WILLBE REASON IF MOTOR PROTECTION RELAYS SHOWS LRC TRIP?
Re: TRANSFORMER/ HT MOTOR
04/29/2011 10:23 AM
Are you taking a test, or did you loose your text book?
It is considered impolite to type in all CAPS.
04/29/2011 10:57 AM
04/29/2011 12:00 PM
We welcome you to this forum. Please read CR4 rules of conduct, CR4 FAQ. Before you post any question please search this forum. You will find answer for most of your questions .
Good Answers: 42
04/30/2011 12:09 AM
Dear friend,
Since you are new to this site, you should know the ethics and rules of this site. From my experience here Examination questions are not accepted in this site for discussion. If you are a technician, supervisor or engineer or even layman during carrying out the job if you come across technical problems it is discussed here by members and possible solutions are recommended. Even many other technical problems are discussed valuable knowledge is exchanged between people from many countries around the globe. Your questions appears as examination questions. More over answers for these questions are available in fundamental books and also you can get from a search of Google or Wikipedia. So you do not have to valuable time of others. While putting up or answering usage of capital letters are considered shouting and considered as in decent and bad manners. So please read your text books and avoid shortcuts.
05/01/2011 3:11 AM
This appears to be a question paper.Pl read your text book.Always use small letters and avoid using capital letters through out your message.
Good Answers: 170
05/02/2011 2:25 AM
Oops! Answering your queries requires one to write one chapter each on transformers & motors. Please reda J & P Transformer Book and Areva's NPAG.
Register to Reply 6 comments
Anonymous Poster (1); electricalexpert65 (1); lyn (1); nesubra (1); pravinba (1); V.I.Abraham (1)
