Previous in Forum: Electrical   Next in Forum: Transformer / HT Motor
Japanese Semiconductor Replacements
04/29/2011 8:55 AM
I am tryng to find a source of replacement transistors and diodes for a driver board on a cnc machine with some 2SB1091 (HITACHI low freqency power amplifiers) S5KD20(high speed centre tapped diode doublers) and 2SD1572 transistors the board is about 1987 year of origin, have had no luck so far in uk does anyone no of more modern numbers or sorce for same.
Good Answers: 97
Re: JAPANESE SEMICONDUCTOR REPLACEMENTS
04/29/2011 9:31 AM
Hitachi has been renamed transformed to Renesas
or try google for "2sb1091 replacements" = 2SB1019 Si pnp 30W 70V 50V 5V 7A 175>C - - 100T MAT TO220-1 Power General Purpose - 2N6314 KT837V
Good Answers: 88
04/29/2011 9:36 AM
TIP147 for B1091 and TIP142 for D1572 should work fine as for the darlingtons. You could add 5k resistors from B to E for full compatibility. 2 discret 5A+ fast recovery 200V+ diodes can do the job if you can't find equivalent diode pack and have the space. 2 diode markings should be on S5KD20 to quide you on connection.
05/17/2011 9:12 AM
Hi thanks for the imformation on the transistors (TIP147 & TIP 142) have been able to get these easily but cannot find any s5kd20 diodes, can use two diodes to replace it but cannot configuire the arrangement of the diodes as originale is kaput can you please help ie is pin 1 anode pin 2 cathode pin 2 anode pin 3 cathode or vice versa any help you can give would be very gratefull (sorry about delay but have been away) regards.
Good Answers: 46
05/20/2011 7:00 PM
Hello, In the first scan is the pinout on the diodes look for 273C. In the PDF link below the first PDF gets the spec page the S5KD20 INFO near the bottom of the page.
From datasheet Archive for S5KD20 scroll down page to find PDF links.
Hope this helps.
There are a few places to buy the part but I think they want to sell in volume.
Here a Google translate page.
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Good Answers: 46
Re: Japanese Semiconductor Replacements
04/29/2011 3:24 PM
Try here at Newark for 2SB1091
Try here for 2SD1572
Also here is the datasheet and cross reference at the bottom of page for 2SD1572
Newark may have one of the cross reference parts.
Here a data sheet from ONSemiconductor for MUR1620CT cross for S5KD20
Try here at Newark for MUR1620CT
Hope this helps you.
Charles
Good Answers: 88
04/29/2011 4:41 PM
Small correction MUR1620CT won't fit because it's two diodes with common cathode, S5KD20 config is two diodes in series with tab in the middle. Something like half bridge.
Good Answers: 46
04/30/2011 3:39 AM
my bad.
I'll look some more.
Register to Reply 7 comments
BS15 (1); Hendrik (1); metalSmiths (3); SimpleMind (2)
