Previous in Forum: Transformer / HT Motor   Next in Forum: Cable Calculation
Speed Sensors
04/29/2011 1:06 PM
Dear all,
In conveyor, how effectively do you use speed sensors ?
Thanks & Regards,
Re: Speed Sensors
04/29/2011 3:19 PM
Very effectively, thank you.
Good Answers: 181
Re: Speed Sensors
04/30/2011 7:32 AM
Had the odd failure, but usually very effective.
Re: Speed Sensors
05/01/2011 6:54 AM
Assuming a conveyor having following pulleys in order as :
1. Drive Pulley ( Discharge also )
2. Drive Snub Pulley
3. Drive end bend pulley
4. Vertical Take up pulley
5. Tail end bend pulley
6. Tail pulley
Where will you fix the speed sensor ? Why ?
Regards,
Re: Speed Sensors
05/01/2011 7:23 PM
It really depends on the application and the precision you require.
Can you provide more information on your application and what the speed measurement is going to be used for (eg- general indication, basic process control, accurate speed control, belt breakage monitoring, etc).
Register to Reply 4 comments
Anonymous Poster (1); jack of all trades (1); Sganesh (1); TonyS (1)
