Previous in Forum: Centrifugal Pumps Are In Parallel   Next in Forum: Question About Material Of Valve
14 comments
Cost Of Water Wheel Construction
04/30/2011 9:38 AM
I'm wondering how much would be the cost of constructing water wheel whose diameter = 3m and width= 2m. I need to know the cost of both wooden made wheel and steel made wheel. Any information on this will be really appreciated. Thanks :)
Re: Cost of water wheel construction
04/30/2011 9:44 AM
Have you done any independent research, yet? If so, what have you found?
04/30/2011 10:01 AM
You might luck out and find someone here that has built water wheels of those exact dimensions, out of both wood and steel, and tracked how much each cost......................otherwise, you're going to have to put together a material list for each and do some shopping around.
04/30/2011 10:05 AM
It's homework. All he wants is the answer.
04/30/2011 10:39 AM
I want someone to come and do the mountain of yard work I have to do today that I've been putting off.
04/30/2011 11:02 AM
I just quit watering my grass. It's brown now and hardly ever needs mowing.
As soon as my wife figures that one out, I'll have to go back to watering and mowing.
Good Answers: 97
Re: Cost Of Water Wheel Construction
04/30/2011 11:32 AM
$1000000000000000 (ZIM) if you buy today.
04/30/2011 12:20 PM
As Cornelius Vanderbilt supposedly said; if you have to ask, you can't afford it.
04/30/2011 12:41 PM
Surely the answer should be almost zero?
You design around the materials to hand and recycle where possible, I mean you don't want NASA to design the darned thing do you?
A trip round the local car breakers/council rubish tip/back of the local industrial units should provide inspiration or try googling DIY water wheel.
04/30/2011 12:52 PM
Translation from English (GB) to English (USA)"A trip round the local car breakers(junk yard)/council rubish tip" (dump)
I marked this OT, but I don't know why.
Good Answers: 196
04/30/2011 11:50 PM
Estimate the physical volume or weight of the water wheel material. Multiply that times the unit cost of the material to get a total material cost. Rough estimate of fabrication labor cost as equal to the material cost. This labor cost should include a factor for overhead costs. If the construction of this water wheel is to be contracted out to another business entity you should add percentage amount to cover gross margin for the contractor. In uncompetitive situations gross margin adder will run 100 to 150%. In highly competitive situations the adder may be as low as 10 to 25%. Now add in packaging and shipping costs, taxes and import duties. That's your total.
The rest of you can argue with me; but the 50-50 labor-material ratio works suprisingly well for situations involving industrial sized machinery and equipment for a rough first estimate of cost.
Ed Weldon ( a cost estimator gig bought me groceries for most of a year late in my engineering career.)
Good Answers: 181
05/01/2011 3:06 AM
http://en.wikipedia.org/wiki/Laxey_Wheel
How much power do you need?
05/01/2011 9:21 AM
Wood cost is greater than $10 US - Steel is more, but that's just an approximation based on the information given.
Good Answers: 75
05/01/2011 10:16 AM
Forget about a water wheel build a turbine instead, not only will it be considerably more efficient but can be made smaller than a similar specification water wheel.
Good Answers: 70
05/01/2011 3:41 PM
It's pretty scary, that some one with a handle of "MechEngMaster" come to CR4 for basic math calculations
Register to Reply 14 comments
dj95401 (1); Ed Weldon (1); Hendrik (1); kramarat (2); lyn (4); masu (1); redfred (1); Tom_Consulting (1); TonyS (1); user-deleted-1105 (1)
