Previous in Forum: Question About Material Of Valve   Next in Forum: How to Design Horizontal and Vertical Thermosyphon Reboilers
Flat Head Design
05/01/2011 7:05 AM
I have a flat head with two openings to designed as per ASME VIII Div2. These two openings are closed by a smaller flange attached to the head by bolting . Since the opening is not having welded nozzle, I can consider reinforcing area from head only. But this requires thicker head. Is there any option to design the head economical apart from FEA.
RK
Good Answers: 53
Re: Flat Head Design
05/01/2011 3:51 PM
You incorrectly presume that because you know what you are talking about others do as well. You would stand a better chance of getting some help if you provide context, application details, drawings etc..
I have a round head with seven openings. Could it possibly be any thicker?
05/04/2011 10:07 AM
I would suggest you thump the unfriendly type who gave you the flat head in the first place and don't try and blame any of us!!!!!
In fact, although a peaceful type, may I suggest you thump him TWICE as hard, he deserves it!!!
Register to Reply 2 comments
You might be interested in: Flat Belt Pulleys, Flat Panel Displays, Flat Springs
