Previous in Forum: Hard Starting Electric Motor   Next in Forum: Professional Electrical Supervisor Training Course
Voltage Drop Calculation as Per Indian STD
05/05/2011 12:21 AM
how to calculate the voltage drop as per indian std ,if the cable size is in sqmm.
Re: Voltage drop calculation as per indian std
05/05/2011 3:47 AM
1. Find the Indian equivalent of British Standard 7671.
2. Apply the contents.
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
05/05/2011 4:42 AM
The best way to do it is to do it yourself by starting from the zero ground. Do you have any Indian std there? Where you find you have difficulty, post it up here. With the experience from gurus here, they will help.
Anything that can go wrong, will go wrong
Good Answers: 170
05/05/2011 5:47 AM
Oh! I am sick of answering the same question - possibly to the same person - again & again. Look, Mr. Anonymous, there is an Indian Standard Code of Practice for the Selection, Installation & Maintenance of Electric Power Cables up to 33kV. The Standard No. IS 1255. In this IS, there is a clear Table, which prescribes the maximum permissible volatge drop per km per Ampere for various types & sizes of cables. This should be taken as a guideline & the actual voltage drop in your cable installtion should be calculated accordingly taking the Type, Size, Length & Ampere Loading of the said cable.
Is it OK or do you still want us to spoon-feed you?
electricalexpert65 (1); hien.nguyenquoc (1); PWSlack (1)
