Previous in Forum: ATMEGA 8515 Microcontroller Application Usage   Next in Forum: Voltage Drop Calculation as Per Indian STD
20 comments
Hard Starting Electric Motor
05/05/2011 12:20 AM
The 1/3 hp brushless motor on my drill press needs help starting by spinning the armature. How can I trouble shoot it. It does't have a starting capacitor.
Re: hard starting electric motor
05/05/2011 1:47 AM
poster #1; it may be a split phase which has a starting switch/contacts, the contacts may have dirt on them or the mechanical centrifugal Governor may not be working.perry
Re: haerd starting electric motor
05/05/2011 1:56 AM
There may be some binding or lack of lubrication in the spindle. 1/3 hp is rather light-duty, and might stall with just a bit of stickiness in the rotating parts.
05/05/2011 5:07 AM
thanks. i've already checked. i don't know how to check the armature and windings.
Good Answers: 88
Re: Hard Starting Electric Motor
05/05/2011 10:06 AM
At this power level I suspect it's a capacitor start motor with a well hidden dead capacitor.(LOL). If not check the start relay or if applies the centrifugal switch. S.M.
05/05/2011 10:40 AM
Throw that one away and buy a new one.
5 Speed Drill Press
Item #38119
(57)
Only:$89.99
Sale:$69.99
05/05/2011 12:11 PM
I don't know what DP you have, but if it is a pretty good one, replace the motor with a 1/2hp motor after you check for the possible motor faults mentioned by the other posters. If it is an el cheapo like the $69.95 one mentioned, you might want to buy a better one. How much you spend depends on your use.
Mr.Ron from South Ms.
05/06/2011 4:31 AM
thanks for the advise. it's an old delta that's made better than the new ones out there. i have the motor apart an there's no starting relay. no binding. does anyone know how to trouble shoot the windings and armature?
Good Answers: 130
05/06/2011 5:52 AM
So you are saying it's 3 phase?
If so, it's lost a winding/phase.
Each winding (wire pair) should return the same ohms ± a few %
You may need a low ohms scale to detect the anomaly.
Good Answers: 88
05/06/2011 9:11 AM
If it's a 3-ph motor the wise approach is first to test the switch. One bad contact could be the problem.
Good Answers: 130
05/06/2011 9:19 AM
good thought
Good Answers: 19
05/06/2011 11:14 AM
And be sure to Ohm the windings at the motor leads, not from the switch leads. I have seen to may motors fall tot he junk yard because a wire in the SO Cord feeding the motor has broken internally. New motor same problem......OOPS change the cord.
05/06/2011 5:24 PM
it's just a single phase 1/3 hp 120v 1600 rpm motor. only 2 wires coming from the windings.
05/06/2011 8:55 AM
Never mind my suggestion. Fix it, it's worth it, even if you have to buy a new motor.
Good Answers: 40
05/06/2011 12:56 PM
<sigh> ... If you've got it apart, "A Picture's Worth A Thousand Words", if you can't supply nameplate data.
Before any more posters jump-in-under-the-assumption that you must be dealing with a 3Ø motor or a 'universal' motor or a repulsion-induction motor or some other type ... (because that's what either THEY or their grandaddy had some experience with), GIVE US A CLUE!
There are scores of other such threads (electric motor difficulties) all-over CR4 ... and they ALL mandate some "Specififications" be given, before any "worthy" advice can be fed-back.
Just my (first) 2-cents here.
[And, for what it's worth, I'm willing to wager it's a split-phase motor with a centrifugal start-winding switch on the "back-end", opposite the shaft...yes/no?]
Q: Can you make it run in EITHER direction by giving it a "spin/push" in either direction from a dead-stop?
Anonymous Poster #2
05/06/2011 1:45 PM
As you'll soon find out, reading crystal balls is part of the fun S.M.
05/06/2011 5:27 PM
nope. no starting circuit
05/06/2011 5:31 PM
but i'm considering putting a starter relay on it.
Anonymous Poster #2
05/06/2011 8:51 PM
You are some genuine piece of work. After your 5 posts over your original question you fail to give seriousl info about it. That must be a new record.
Good Answers: 40
05/10/2011 10:00 AM
I am inclined to feel the same as "Anonymous Poster #2" at this point.
You say there is "no starting circuit", and yet, you think you're going to add a "starter relay"...(with only *2* wires coming from the windings)...?
How do you intend to connect the relay?
Where is the PICTURE , previously solicited...(Post 13)?
Seriously ... a 1/3hp 1600rpm rating ... on a Drill Press ...? Go with 34Point5 on this:
"That being the case, take Lyn's advice 5"
Or, with some angle-iron and perhaps a new belt, you could accomplish a retrofit... ... similar to this one.
"PS" ~ Your response : "nope. no starting circuit", to my question ("Q") at the bottom of post #13, indicates that you did not get "my drift".
IF your motor was of the "split-phase" variety (with a bad/defective starting circuit/winding/switch/capacitor/whatever) ... then, while it is sitting there "buzzing" (but not rotating) upon energization, you WOULD be able to make it RUN in either direction by giving it a starting-spin in whichever direction you chose.
Good Answers: 130
05/06/2011 8:07 PM
Ok, so it's not 3 phase.
If you are sure that;
A. there is no capacitor, mounted on it, or wired to it
B. no centrifugal switch inside the motor case - i.e. it never made a 'click' sound when slowing to a stop?
It leaves "resistive start" type - then what you are looking at is replacing a PTC thermistor (special type of resistor) that has died.
Reply to Forum Thread 20 comments
34point5 (3); Anonymous Poster (3); jlstitt (4); lyn (2); ndt-tom (2); perry (1); ronseto (1); SimpleMind (2); Stedou73ish (1); Tornado (1)
You might be interested in: Brushless Motors, Motor Coils, DC Motor Drives
