Previous in Forum: Outer Sleeve for Small Diameter Wire Rope/Cable   Next in Forum: Sprinkler Head
8 comments
Steam Condenser/Nitrogen Heater
05/06/2011 2:23 AM
Dear all,
I'm engineer from Germany in the field of air separation units.
We search for world wide suppliers/designers/manufacturers for an apparatus, which desuperheat, condensing steam and subcool the condensate to 80° C on tube side, while nitrogen shall be heated to approx. 200° C on the shell side.
Does anyone knows suppliers, which can design (thermal and mechanical) and manufacture such equipment? Currently we need this "exchanger" for projects in USA and India.
Thanks so lot for any help.
Mangus
Re: Steam Condenser/Nitrogen Heater
05/07/2011 1:01 AM
We can make it . Please send your enquiry
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
RK
Good Answers: 19
05/11/2011 11:53 PM
Ha ha. mail me your broucher
Good Answers: 67
05/07/2011 3:09 AM
Contact any heat exchanger manufacturer giving details like in and out temperature, pressure and fluid quality and flow rates. I am sure you will get immediate response. In India you can contact M/s GE, Bhopal.
05/07/2011 1:11 PM
There are many reputed manufacturer in India. you can contact any of them. few names are as below:
M/s GMM Prafoudler,
M/s ISGEC Yamuna Nagar,
M/s Godrej Boyece,
M/s Lloyeds,
M/s Patel Air temp,
M/s L&T,
M/s ESSAR Engg. etc.
Good Answers: 19
05/11/2011 11:55 PM
Mukesh - Why have you not mentioned name of mrkmech
Good Answers: 19
05/11/2011 11:55 PM
sorry brkmech
05/12/2011 12:12 AM
The first reply is from brkmech themselves, no need to repeat their name.
05/11/2011 10:23 AM
Hi,
You can also try Chart Industries which is U.S. based. An
Internet search should bring it up for you.
Register to Reply 8 comments
brkmech (1); ducon (3); enger (1); Mukesh0861 (2); pritam (1)
