Previous in Forum: Why Current Will Not Pass in Induction Furnace Water   Next in Forum: Installation Procedure for Electrical HT LT Panels
9 comments
Difference Between 2 Watt Meter and 3 Watt Meter
05/11/2011 6:24 AM
Can you tell me the diffeence between 2 watt meter and 3 watt meter please ?
Re: Difference between 2 watt meter and 3 watt meter
05/11/2011 6:31 AM
Maker's details?
Part number?
05/11/2011 6:35 AM
what do you mean by maker's details and part number .. ? I just have a question in my project it says like this .. : Compare two different methods of power measurments in a three-phase system for both balanced and unbalanced loads .. and i have choosen the 2 watt meter method and the 3 watt meter method .. can yo help me in this question please ?
05/11/2011 6:38 AM
A 2-wattmeter is basically used for balanced/un-balanced loading when 3-wire system is used. When 4-wire system is used (ie, Neutral included), 3-wattmeter method is used to measure the power.
The important thing is not to stop questioning.
05/11/2011 6:41 AM
so thatas the only difference between the two systems ?
05/12/2011 5:14 AM
1st learn to ask question: if somebody is showing some willing to help you, Then answer him in a manneralble way regardless of result.
People(Experts) here are masters in their field and are really good and honest in answering all the queries. They are not your home tutors.
My personal feeling, May be others dont agree. Hope you 'll take it +vely.
Thanks and best regards.
05/11/2011 7:03 AM
Uh....one watt.
J B
Re: Difference Between 2 Watt Meter and 3 Watt Meter
05/11/2011 7:42 AM
Since this is a homework Project question, it will not be proper to get the reply here. After all you must get to the answer yourself.
try to construct a 3 phase 3 wire system with balanced load and check whether the wattmeter will always give the corerct answer. Do same with 4 wire system. Now try out with unbalanced loads. try with floating neutral and then with neutral grounded see where you get a different answer and why.
When you get a problem like this, you must think
(a) If 3 wattmeter costly method exist, it must have a certain advantage.
(b) Where the cheaper method fail to provide accurate result.
Good Answers: 181
05/11/2011 9:27 AM
Now you know the policy on homework on this site.
02/15/2012 5:06 AM
hi friend:
here you can find some thing to help u
http://www.sari-energy.org/PageFiles/What_We_Do/activities/Afghan_Capacity_Building_Program_Aug_09/tp_on_metering_tech_and_systems_may_17-29_2010/presentations/170510/ENGLISH/Measurement_of_power_in_single_and_3_phase_circuits_170510.pdf
goodbey
sokrer
Register to Reply 9 comments
Anonymous Poster (1); Arham (1); JBTardis (1); Madhusudhana (1); PWSlack (1); Sarcia (2); sokrer (1); TonyS (1)
