Previous in Forum: Difference Between 2 Watt Meter and 3 Watt Meter   Next in Forum: Where in the World??????
8 comments
Installation Procedure for Electrical HT LT Panels
05/11/2011 6:32 AM
Does anyone Know the Detail installation procedure for HT & LT panels ?
Re: Installation Procedure for electrical HT LT panels
05/11/2011 7:28 AM
Yes. The manufacturer of those panels does.
Good Answers: 181
Re: Installation Procedure for Electrical HT LT Panels
05/11/2011 9:29 AM
Put them in the correct place and connect wires between them.
If you want a sensible answer ask a sensible question!
05/11/2011 10:00 AM
Hi, All
if you gonna procure panel from the supplier and will mount into the substation or outdoor please request the procedure from the supplier and endorse to client before the installation.
Also during the install please ensure the safe handling, failure of installation lead to delay of testing/commissioning.
Regard's
Good Answers: 170
05/11/2011 9:56 AM
Best way is to follow the Panel Manufacturer's Installation Manual & Drawings.
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
05/11/2011 11:13 PM
electricalexpert65:
I am guessing that the OP was exactly the one who asked for LT panel overtemperarure.
Dear OP: Could you kindly teach me what is HT and LT panels?
Anything that can go wrong, will go wrong
05/12/2011 1:21 AM
HT = high tension, same as high voltage. Likewise LT.
05/11/2011 4:05 PM
Additionally you need to follow your local electrical standards and regulations.
The installation also needs to be done by a qualified professional.
05/12/2011 3:19 AM
Which party are you working for? Customer? Contractor? Or supplier?
electricalexpert65 (1); hien.nguyenquoc (2); jack of all trades (1); PWSlack (1); ronron (1); TonyS (1); Tornado (1)
