Previous in Forum: How to Calculate Process Filter Size   Next in Forum: Insulating Steam and Condensate Lines Together
CFM of the Fan
05/11/2011 8:40 AM
my fan impeller dia 1270 mm and width is 330 mm and rpm is 1234 what will be the cfm of the fan?
Re: CFM of the Fan
05/11/2011 10:02 AM
You also need pitch, twist and blade count. Just use an anemometer.
Good Answers: 19
Re: CFM of the Fan
05/11/2011 11:42 PM
to continue further with what Anonymous has adviced , long on to:
www.ehow.com/how_6494748_calculte-cfm-rpms.html.
... a little googling would have helped.
Re: CFM of the Fan
05/12/2011 3:52 AM
What does the original equipment manufacturer's performance curve say?
Re: CFM of the Fan
05/13/2011 12:43 PM
With these data nobody on the earth can tell you CFM of your fan. Designers put their brain to design the optimum size for the for the best efficiency flow. If flow is not known you have to meassure it by meassuring velocity at the outlet cross section then you can use your maths.
Good Answers: 67
Re: CFM of the Fan
05/19/2011 9:17 AM
Fan is designed to meet certain flow rate (cfm) and pressure at outlet (static or total). To answer your question some more data like fan type (centrifugal or axial),outlet pressure, impeller eye diameter. type of blading (radial, forward or backward curved), blade angle etc. are required.
However, assuming centrifugal fan with this limited data, I can say that it may give about 110,000 cfm.
Anonymous Poster (1); ducon (1); Mukesh0861 (1); pritam (1); PWSlack (1)
