Previous in Forum: Bus Bar   Next in Forum: REF_541 Relay Set and Testing
Induction Motor Supply
05/13/2011 2:05 PM
The type of supply for an induction motor must be
1) a.c only
2) d.c only
3) a.c or d.c
4) rectified a.c
I think its a.c or d.c what do you think. Thank you.
Re: Induction Motor Supply
05/13/2011 2:22 PM
I guess it would depend on the desire to see the motor spin.
Check your textbook, look for some guidance on electromagnetic induction.
Good Answers: 804
05/13/2011 3:06 PM
I think you should learn not to try to get other people to do your homework for you. You only learn how to be a leach that way.
05/13/2011 4:28 PM
I don't think what you think.
Some other possible multiple choices for this test question:
5) none of the above
6) some of the above
7) most of the above
8) all of the above
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
05/14/2011 2:36 AM
I quite cannot understand what you mean by that. For you, what motor should be considered as an induction motor? Having answered that question, you will be clear of what you want.
Anything that can go wrong, will go wrong
Register to Reply 4 comments
Doorman (1); hien.nguyenquoc (1); JRaef (1); Tornado (1)
