Previous in Forum: Induction Motor Supply   Next in Forum: Flux Factor With Respect to Tube Lights (Lumens)
REF_541 Relay Set and Testing
05/13/2011 5:11 PM
I need some help. The REF_541 relay setting programmed to "Very Inverse", but when I go to Doble Protest Program to test the relay, (this is the old relay in service and need to be tested, how do we know which curve to use), The relay test software has options to select and the curves are quite differrent from each other, the options are:
DPU: IEC Very Inverse
DPU: US Very Inverse
IKC911: BS142 very Inverse
MMCO: IEC Very Inverse
REL501_V2: IEC Very Inverse
SPAJ110C: Very Inverse
Good Answers: 19
Re: REF_541 Relay Set and Testing
05/13/2011 11:14 PM
Please refer to ABB.
Ramesh,Freelance Electrical/automation Consultant
Good Answers: 22
05/15/2011 5:48 AM
Choose IEC Very Inverse. You are most likely to be right with ABB make relays. To be sure, you can refer the REF541 relay manual (available in ABB website for free download).
Raghunath
