Previous in Forum: I Beam Weight Limit   Next in Forum: Fire Rated Wall (Definition and Standard)
8 comments
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Is There Any Difference Of Masonry, Brick Wall Or Dry Wall?
05/14/2011 7:49 AM
Just wanna confirm, is there any difference among brick wall and masonry wall or dry wall?
Anything that can go wrong, will go wrong
Good Answers: 48
Re: Is there any difference of masonry, brick wall or dry wall?
05/14/2011 7:56 AM
Brick is a type of masonry, so a brick wall will be a masonry wall. But a masonry wall will not necessarily be a brick wall, because masonry also includes such as stone, concrete blocks, clay blocks, etc.
Good Answers: 266
Re: Is There Any Difference Of Masonry, Brick Wall Or Dry Wall?
05/14/2011 8:16 AM
http://en.wikipedia.org/wiki/Dry_wall
http://en.wikipedia.org/wiki/Masonry
Boy that was easy, pretty good definitions of the differences between them.
Didn't look up brick wall it's pretty self explanatory. A wall made out of brick.
05/14/2011 8:28 AM
Boy??? Well...sniffing
05/14/2011 8:36 AM
hien,
No offense intended, but your internet browser is more than just a gateway to CR4....................it's also a search engine. Yep, you can actually type a word or term into the search window, push enter, and a list of answers to your query pop up.
Check it out, it's pretty cool.
05/14/2011 11:07 AM
I agree with kramarat. You could at least try a search or two, before coming here to ask elementary questions.
As a matter of fact, I will no longer respond to any question from you, unless you post at least two web sites that proves you made a little effort to do your own work.
Have you ever searched for any information before coming here,(Google, wiki, etc) or are we your free reference library?
Do your own work!!!!!!!!!!!!!
05/14/2011 11:35 AM
Having tried the page before so I need confirmation as in my first post.
05/14/2011 12:53 PM
Oh, my bad. It's just a confirmation.
Yes, there is a difference.
Sorry for the misunderstanding. For a minute I thought you wanted us to do an internet search, find reliable published reports on each item, and post them here for you to peruse at your leisure.
Hope this helps.
05/15/2011 10:54 AM
A masonry wall is made of solid units such as bricks, stones, blocks, etc., and held together with mortar. Such walls are weather proof (practically speaking). However, DRY WALL is made of mined material. From Wikipedia:
Drywall, also known as plasterboard or gypsum board, is a panel made of gypsum plaster pressed between two thick sheets of paper. It is used to make interior walls and ceilings.
Register to Reply 8 comments
hien.nguyenquoc (2); Holzfeller (1); kramarat (2); lyn (1); ozzb (1); WoodwardDL (1)
