Previous in Forum: Is There Any Difference Of Masonry, Brick Wall Or Dry Wall?   Next in Forum: How To Build and Test ESD Floor?
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Fire Rated Wall (Definition and Standard)
05/14/2011 7:55 AM
Yes, it is all about walls. My question is:
Is fire rated wall means fire-proof wall? According to US, what is the code for this? NFPA?
In a certain aspect, can we utilise the concrete wall as fire rated? What make the difference of a fire rated wall and the standard walls?
Anything that can go wrong, will go wrong
Good Answers: 266
Re: Fire Rated Wall (definition and standard)
05/14/2011 8:36 AM
No fire rated is the wall will with stand a fire for some rated length of time. Yes a concrete wall has a fire rating. As does dry wall. Note that any opening in the wall like a door must have a fire rated door. The fire rating on the total wall is dependant upon these devices that fill the openings. The wall rating is then the lowest rated device.
To learn more about fire walls get copy of NFPA 221
05/15/2011 2:22 AM
This is in addition to Ozzb's comments. Fire rating of door to be mentioned clearly in the specifications . It should be as per NFPA standards or local standards. If a building is to be designed as flame proof one all fittings are also to be flame proof.
Good Answers: 27
Re: Fire Rated Wall (Definition and Standard)
05/15/2011 8:30 AM
Please understand that being "fire-proof" means that it is not or never will be affected by exposures to any heat or fire sources regardless of time! NFPA materials ratings are for being 'fire-retardant', which means that the materials used are rated with certain amount of delay time before being burned and highest temperature it can withstand before becoming susceptible to any flame, heat and direct fire exposure. It is a life-safety issue as addressed by the NFPA!
vsar
Good Answers: 19
05/15/2011 9:18 AM
Fire rated is not fire proof.
Fire rated is an assembly that has been tested by methods described by ASTM and NFPA (if in the USA) and passed.
A good source of these assembly details is found on most drywall manufacturers web sites. The concrete and masonry associations have similar info on theirs.
There's a theory stating if anybody discovers exactly what the Universe is for & why it is here, it will instantly disappear & be replaced by something even more bizarre & inexplicable. There's another theory stating this has already happened.D Adams
Register to Reply 4 comments
Geode Hunter (1); mrswamy (1); ozzb (1); vsar (1)
